Is a 1967 Falcon Gas Pedal assy same as 1969 Falcon ?
falconcritter
Post #1 by falconcritter » Mon Apr 23, 2018 4:32 pm
Is a 1967 Falcon 6 cyl Auto Gas Pedal assy the same as a 1969 Falcon 6 cyl Auto assy ? Can anybody post a picture of a 67 assy on the rear of the firewall ?
1969 Ford Falcon 2Door and future home for my Australian 250 2V , 2013 Ford F-150 Single Cab , 2018 Ford Escape S
rbohm
Assistant Admin
Re: Is a 1967 Falcon Gas Pedal assy same as 1969 Falcon ?
Post #2 by rbohm » Fri May 04, 2018 4:04 pm
i am going to say it should be since the cars are the same body style. when i swapped to the two barrel carb on my 66 falcon, i used a V8 peal assembly from a 68 or 69 falcon as i recall. the only thing i had to do was cut off the kick down lever on the assembly becaue it would fit around the manual trans clutch linkage.
64 falcon
66 mustang
05 grand marquis
transient nodes of thought
of invention
falconcritter
Post #3 by falconcritter » Fri May 04, 2018 6:27 pm
They are basically the same . I was at a small classic ford junkyard in Orlando and he had a 67 and a 69 both six cyl , auto cars . The kickdown on the transmission was different between the years that was all .
