1964 falcon with a 250 swap
mgerhold
New Member
Post #1 by mgerhold » Tue Oct 09, 2018 8:51 pm
i have a 64 falcon that i am looking to drop in a ford 250 maverick engine in. does any one have some close up photos so i can see how this motor sits in a 64? also any suggestions for a pusher fan. my understanding is that its a tight fit at the front so you have to have a pusher between the radiator and the grill. any info would be appreciated.
cobraguy
Re: 1964 falcon with a 250 swap
Post #2 by cobraguy » Thu Oct 11, 2018 9:57 am
First welcome to Fordsix. I put a 250/C4 in my 62 and it's a squeeze but doable. Yes you need a pusher fan in front of the radiator. I had to flip my center link not sure if that's necessary on the 64. There is a lengthy build thread (66 pages) on the Comet Central forum
http://cometcentral.com/forum/viewtopic.php?f=9&t=13058
Lots of pictures and good info. I'm following the build because he's a couple steps ahead of where I am on my Mustang II install.
62 Falcon 2 dr sedan 250/C4 8" "Magoo"
63 Ranchero 200/SROD DS II, Weber "Barney" SOLD
B RON CO
Post #3 by B RON CO » Sun Oct 14, 2018 8:50 am
Hi, get the Ford Falcon Performance Handbook. There is info there on the swap you are planning to do. Good luck
1966 Ford Mustang - 289 V8
