All Small Six Small Six Tech (sticky's)
Status
Not open for further replies.
AzCoupe
1K+
Departed Member
We were getting so many STICKY's that I decided to condense them into one thread. If you come across a good topic that should be added to the list, just post a request below. Make sure you include the topic title and the link. Then one of the moderators can check it out and add to the list if they agree with the recommendation. When the list starts to get to long, I'll categorize the topics. Thanks.
If you don't find the answer to your question here, you can use the search function at the top of the page. Just type in a few of the key words, then hit the search button. Chances are you'll find your answer, as our data base of old topics is huge.
You can also check out the Tech Section on Classic Inlines' website, which has a great selection of articles pertaining to the small six. Plus were always adding new ones. Magazine Articles are also a good source of information.
Weber Reference Table - Work In Progress
viewtopic.php?f=1&t=49901
Flow testing the "log" heads
viewtopic.php?f=1&t=62208
Small Six Head Swap
viewtopic.php?t=1027
Pre-68 Load-O-Matic - How it operates
viewtopic.php?t=15522
or http://classicinlines.com/Loadomatic.asp
Manifold vs Ported Vacuum
viewtopic.php?f=1&t=63354
Rocker Arm Shaft Oiling hints
viewtopic.php?t=29111
Modifying a Carter Super Pump
viewtopic.php?t=36991
How the Spark Control Valve (SCV) Works
viewtopic.php?t=18841
Holley/Weber 32/36 Jetting Tips
viewtopic.php?t=23153
Duraspark II Conversion
viewtopic.php?t=21002
viewtopic.php?t=53797
Modify the DSII for Better Mileage
viewtopic.php?t=30894
2V Dyno Results - Part 1 & 2
viewtopic.php?t=52903
2V Dyno Results - Part 3 & 4
viewtopic.php?t=54061
Pictures of Throttle cable set up??
viewtopic.php?t=54405
Small Six Identification?
viewtopic.php?t=54747
New Exhaust Products
viewtopic.php?f=1&t=59094
Arvinode Exhaust Systems
viewtopic.php?f=1&t=60441
Great idea, Mike. Thanks! No wonder you're a moderator! Really like the 'topics' U selected...
'Course I'd like one bout (TOPIC) swapin the 250 into a Bronco ('66 - '77). I'll look up all the threads if U know it'll be 'accepted'.
:twisted:
Status
