2018 Contributors:
Tri-Power Carburetor Options?
kboldin
Post #1 by kboldin » Fri Jul 26, 2013 2:28 am
Looking for a little advice for my next steps. I was able to purchase a Offy manifold that came with three Holley 1904’s, I also have on the shelf two Carter YFA’a. Which would be the better set up, the Holley’s or Carter’s? (I have a 200ci, large log) The center Carter would have a hot air choke while the center Holley would be a manual choke. I also think the Carters will flow more CFM although I could not find any data on the Holley's. All input welcome!!
rbohm
Assistant Admin
Re: Tri-Power Carburetor Options?
Post #2 by rbohm » Fri Jul 26, 2013 2:40 pm
8) either would be a good set up, and yes the carters do flow more than the holleys. one thing though, be sure to match the carbs, IE use all holleys or use all carters, dont try to run a single holley and two carters otherwise you starve the center cylinder compared to the outer ones. the reason for the three carb set up is to get more and better airflow to the outer cylinders.
64 falcon
66 mustang
05 grand marquis
transient nodes of thought
of invention
Post #3 by bubba22349 » Fri Jul 26, 2013 3:16 pm
X2 there could be lots of different carbs used on that intake, Holley's 1904's, 1940's, the Carter YF's, Weber ICE's, Autolite 1100 or 1101's. you could also use a different center carb on a progressive linkage system. I am hunting for the Holley's for mine going for the older vintage look. Good luck on your tripower. :thumbup:
CZLN6
Post #4 by CZLN6 » Fri Jul 26, 2013 3:29 pm
Howdy All:
Just curious K, What distributor will you be using? Will you be running vacuum advance? Personally I love to looks of the Glass bowl Holleys.
Good Luck.
kboldin
Post #5 by kboldin » Fri Jul 26, 2013 4:32 pm
CZLN6 wrote:Howdy All:
Good Luck.
Right now I have two dizzy's, a standard dizzy with pertronix and vacuum advance that I'm running on my daily driver and a DUI. I've not got that far, I may not use either.
kboldin
Post #6 by kboldin » Fri Jul 26, 2013 4:39 pm
I like the idea of the glass bowl Holley's but I just don't know yet. I looked over the Offy last night and compared all the inlets, they are two different sizes, the outers are smaller than the center. All the carbs are the same size, the Holley's fit the outer inlets while the Carter's fit the center inlet. I agree that all the carbs should be the same, which ever way I go. I appreciate all the input!
kboldin
Post #7 by kboldin » Fri Jul 26, 2013 6:02 pm
Anybody have a good source on Holley carbs, 1904 variants? I'd like to see if I can get a center carb with a larger outlet and the hot air choke. My center carb is a little different than the outers but they are all 1904's (I believe).
kboldin
Post #8 by kboldin » Fri Jul 26, 2013 7:43 pm
To give everyone a better idea of the setup, I've uploaded a pic. I believe these are 1904's.
chad
Post #9 by chad » Sat Jul 27, 2013 1:46 pm
Thanks for the pic (We Luv Pic!).
Looks like a tight fit, no glass bowls? Is there alot of machining to be done to fit that intake?
Cool it will fit on the newer log (thought it was only for the pre '77).
Who has your linkage? Is that Offy too?
kboldin
Post #10 by kboldin » Sat Jul 27, 2013 3:54 pm
Yes, the log will need to be machined. I'll have to source the glass bowls if I go with the Holley's.
chad
Post #11 by chad » Sat Jul 27, 2013 6:16 pm
Thank you.
The glass fits right on the back of those shown? the 1904s?
Who has them available?
If the cork original gasket rot w/the high alcohol gasoline what could I use now?
Edit:
see above -
< 0 > & < 4 > no longer transposed.
kboldin
Post #12 by kboldin » Sat Jul 27, 2013 10:16 pm
Yes, they use the same screws with metal clips. The originals are hard to find but they look really neat.
Post #13 by xctasy » Thu Aug 01, 2013 3:59 am
chad wrote:Thank you.
The glass fits right on the back of those shown? the 1940s?
kboldin wrote:Yes, they use the same screws with metal clips. The originals are hard to find but they look really neat.
Nah, 1940 and 1904 Holleys don't interchange. The Holley 1940 is the 1970 replacement Holley for the Autolite 1100 and 1101's. Autolite's carburettor division went bust (or more correctly, was made insolvent in 1969 when the inline four barrel for the Boss Mustang failed to get sales, then got proped up by Ford for a few years untill the feds made FoMoCo sell it off to Bendix. The Bendix Stromberg found on later Australian Holdens and Ford i6's is actually an Autolite carb.http://en.wikipedia.org/wiki/Autolite
powerband
FSP Moderator
Post #14 by powerband » Thu Aug 01, 2013 9:08 am
kboldin wrote:To give everyone a better idea of the setup, I've uploaded a pic. I believe these are 1904's.
here's .$,02 more:
... well (AFAIK), the center carb in the pic looks to be a 1904 used on Dodge, Ford, IH, NAsh/Rambler cars and trucks and others for @ 25 years, the outers look to be 1908's ( 1909's?) with similar specs but squarish airhorn/choke used in 60/61 Comet for example.
1904/08 series has either 'big' or 'small' venturi's depending on OEM application/CFM needs and match the Offy adapter's 'big' inner port and 'small' outers (1.00/1.10/1.20). The CFM range of 1904's varies widely but can be coarsely divided by throat size (1-7/16 vs 1-11/16). YF's also have a wide range of applications with different mfg's. Exact OEM specs are determined by the "list number" on carb side but of questionable worth. The glass bowl types are visually most desirable and typically most trouble, glass bowls are available and can replace cast bowl but the clips and bale often mangled or missing. Lately the cork&rubber gaskets used for my glass bowls' has been disintegrating causing leaks probably due to modern gas formula.
1904's can be good performers and YF's probably will perform well if in decent shape. 1904's individually are notorious for warpage, worn out mechanicals and swapped internals ( bad cores sold online as "used"?). 1904's will provide hours of entertainment getting vertical bowl to seal, testing float levels under pressure and drivability/performance. I'm a fan of the 1904 but caution that actual drive-testing each one individually is the only method I've found useful to confirm performance before trying to get three to work together... The progressive OFFY linkage, ( smartly versatile ) uses primary/center "big" carb for idle and cruise so testing for drivability with outers' blocked is highly recommended.
"small"
Image . .Image .
Image . Image
"big" :
Image . Image
YF's:
I have collected "a few" over time to mix and match to optimize performance/drivability and find that grimey dirty old truck type often runs better than an expensive NIB shiny one. 8)
Image . Image
have 3X1 fun
kboldin
Post #15 by kboldin » Thu Aug 01, 2013 9:29 am
xctasy wrote:Nah, 1940 and 1904 Holleys don't interchange. The Holley 1940 is the 1970 replacement Holley for the Autolite 1100 and 1101's. Autolite's carburettor division went bust (or more correctly, was made insolvent in 1969 when the inline four barrel for the Boss Mustang failed to get sales, then got proped up by Ford for a few years untill the feds made FoMoCo sell it off to Bendix. The Bendix Stromberg found on later Australian Holdens and Ford i6's is actually an Autolite carb.http://en.wikipedia.org/wiki/Autolite
I think he meant 1904, the 1940 is a completely different carb. My apologies.
kboldin
Post #16 by kboldin » Thu Aug 01, 2013 1:43 pm
@powerband
I’m not to familiar with the Holley’s but I think I figured out the two on the outside are 1908’s and the inside is an 1904. I don’t think I’ll be using the 1904, I think I’m looking for a 1908 big venturi with an electric choke (if such a creature exists).
After combing through the articles it appears that neither is really a good choice (Holley or CYA’s), folks seem to like the Weber 34’s. I do like the look of the Holley’s but I would have to sell all my carbs and start from scratch. I won’t be needing the spark control valve either, wondering if they can be eliminated? Looks like I have a bit more research to do.
jahearne
Post #17 by jahearne » Sun Aug 04, 2013 2:17 am
This is a write-up I did a few years back on my '66 Ranchero. It's one man's experience. I'm sure there are typos and sentences that are unclear (make sense to me but not the reader). Please send me you suggestions, corrections and criticisms. I'll make the changes.
[TriPower Ford on Google Docs
John
'67 Ranchero 250 AOD
'66 Mustang Fastback
'65 Chris Craft Super Sport
'60 Chris Craft Constellation
rbohm
Assistant Admin
Post #18 by rbohm » Sun Aug 04, 2013 11:21 am
jahearne wrote:This is a write-up I did a few years back on my '66 Ranchero. It's one man's experience. I'm sure there are typos and sentences that are unclear (make sense to me but not the reader). Please send me you suggestions, corrections and criticisms. I'll make the changes.
8) nice write up. :thumbup: :thumbup: i especially like the suggestion of the weber one barrel carbs. something i never even thought of.
64 falcon
66 mustang
05 grand marquis
of invention
64 200 ranchero
Post #19 by 64 200 ranchero » Tue Aug 06, 2013 11:06 pm
i have an autolite 1101 in the center and 2 weber icts for end carbs it is a progressive setup and works great as my daily driver, i think you might want to consider a 1101 as a center carb with your holleys as well did you get the linkage when you got the offy? if not you can use some round galvanized steel stock and some heimjoints to build a very precise linkage setup :nod:
https://www.facebook.com/photo.php?fbid ... =3&theater
60 ford ranchero 200 tri power, modified c4 trans, performance ds2 distributor, msd 6, 3 stage retard, weber ict's, 8" rear end with spool, 3.40 gears, CI dual out header, Flowmaster, 90hp wet nitrous kit.
kboldin
Post #20 by kboldin » Wed Aug 07, 2013 1:56 am
64 200 ranchero wrote:i have an autolite 1101 in the center and 2 weber icts for end carbs it is a progressive setup and works great as my daily driver, i think you might want to consider a 1101 as a center carb with your holleys as well did you get the linkage when you got the offy? if not you can use some round galvanized steel stock and some heimjoints to build a very precise linkage setup :nod:
It came with very little linkage, some of it's usable the rest is headed toward the bin. I like your linkage, reminds me more of a BMW style setup (think e30 M3). Looking at the offy supplied hardware ($100 for the parts kit alone, I priced it) it doesn't look like precision pieces, they look fairly floppy. I have not seen or touched one in person but I've worked on a few dual carb cars and bikes and I believe you are on the right track. With offy parts kit, we are talking 1960's tech. I've saved off the pic for future reference, hope you don't mind. So why didn't you go with all ict's vs. the autolite?
kboldin
Post #21 by kboldin » Wed Aug 07, 2013 2:31 am
Besides being gorgeous beyond belief, check out this triple linkage.
gb500
Post #22 by gb500 » Thu Aug 08, 2013 3:23 pm
australian xk (1960/61) falcon 170 ci race engine ;log cut off and 6 tuned length intake manifolds added
FalconSedanDelivery
Post #23 by FalconSedanDelivery » Thu Aug 08, 2013 3:31 pm
:beer: :wow:
Falcon 6's, FE's I Like them both , Sold all My 6 cyl stuff ( for now at least ) glad to pass along some tips though
kboldin
Post #24 by kboldin » Thu Aug 08, 2013 4:03 pm
That’s a bute! Really-really neet setup! I’ve been doing some research and found a few kits that should be able to be cobbled together to use for our Offy setup. See links below.
The price might be prohibitive (shipping from Australia) but the concept is spot on. I’d like to find a hex-rod and hex-heim joint setup stateside, then buy all the bits and pieces separately, unless somebody is making a kit.
http://compare.ebay.com/like/4003619581 ... s&var=sbar
http://www.weberperformance.com.au/popu ... 26&image=0
http://recarb.com.au/images/cms/dcom_l28_3_400.jpg
http://recarb.com.au/ford-triple-weber- ... -p-86.html
64 200 ranchero
Post #25 by 64 200 ranchero » Wed Aug 14, 2013 9:36 pm
that looks amazing, i didn't go with 3 ict's because i think that it was designed to work with a larger carb in the center since it has a larger bore, i have seen a few people on the forum running 1101's as the center and holley 1904's for secondary's so i thought i would try it with ict's, i chose ict's because the linkage arm is adjustable. i did have to mill the taller carb adapter to match the others thickness then fill the old linkage mounting hole, drill a new hole and tap it, to get it to work properly :nod:
jdn21758
Post #26 by jdn21758 » Thu Aug 15, 2013 11:56 am
i got 3 carter YF carbs,,
it got a nice flow.
greetzz JD.
kboldin
Post #27 by kboldin » Thu Aug 15, 2013 1:04 pm
jdn21758 wrote:i got 3 carter YF carbs,,
it got a nice flow.
greetzz JD.
So how did you overcome the disparity between the center and outer inlet sizes? (By the way, that engine looks super nice!)
