DUI Distributor Shaft & Bushings Binding From Lack 0f Lub.
wsa111
FSP Moderator
Post #1 by wsa111 » Sun Sep 14, 2014 9:42 pm
Any one running a DUI distributor should be aware of insufficient oiling to the distributor shaft & bushings.
I just received & modified another distributor to fix this problem again. The customer was not aware his distributor was very close to being seized.
Anyone running a DUI should remove it & check for potential binding & eventually seizing of the shaft & advance due to a design defect which will possibly starve this area of proper lubrication.
This is a fine distributor once a proper amount of lubrication is feed to the shaft & bushings. Another issue is a rotor which binds the centrifugal advance mechanism. This condition does not occur on every DUI, but should be checked.
The only thing saving many of these DUI's is high crankcase pressure pushing some lubrication to these critical areas.
The Ford DS II is designed properly to prevent both these potential conditions.
Yes this design problem can be fixed, i have done several on DUI's where this problem is present.
I spoke with Performance distributors concerning the rotor problem & they were not aware of this condition. Its very possible the owner of the DUI installed a defective rotor.
The lack of upper shaft oiling has been mentioned before. Bill
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6al & MSD Blaster 3 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
64falconsix
Re: DUI Distributor Shaft & Bushings Binding From Lack 0f Lu
Post #2 by 64falconsix » Wed Sep 17, 2014 4:32 pm
Bill... what info do you need to recurve and what is the charge.... i might as well get mine done while its down for bodywork.also lube mod.....
64 falcon 2dr 200 C.I. .040 decked ,comp. 260 .440, C.I. adjustable timing chain w/ 79 log head 52.cc , offy w/ triple webers , Clifford header , D.U.I. , C/4 2,200 stall , Transgo Stage 2 reprogramming kit , 7 1/4" with 3.20 gears. NX, N2O 75HP shot.
10.29@ 61.91 M.P.H. in the 1/8th mile. 4/12/13
wsa111
FSP Moderator
Post #3 by wsa111 » Wed Sep 17, 2014 5:38 pm
PM sent.
