DUI Upper Shaft Oiling + Distributor Gear Extra Oiling
wsa111
FSP Moderator
Post #1 by wsa111 » Thu Sep 25, 2014 9:19 pm
If you own a DUI distributor you might have upper shaft oiling concerns.
The modification to fix this problem also benefits extra distributor gear oiling in addition to the oiling groove done to #2 & #3 lifters.
This modification involves complete dissembling the DUI to fix this condition.
That would be the time to get the so called custom curved unit modified for your combination.
billythedistributorman@live.com
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6al & MSD Blaster 3 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
