My Mustang Saga
MPGmustang
FSP Moderator
My Mustang Saga
Post #1 by MPGmustang » Thu Nov 25, 2010 11:32 pm
MPGmustang here,
I havn't really started a thread to just push thoughts for other to shoot down, well here it is, this way I don't make too many threads of redundant nonsense.
Here is an accumilation of everything I've been looking into since my my enigne build... Before and After that have really helped me and have taught me something.
Goals:
Getting Started
Most important to fix/replace
performance:
1st Dyno Run!
2nd Dyno Run!
144 with alum head
Jetting a stock pony carb
Engine rebuild
What If (later head swap)
MS Learning Basics TBI Thread
MPG:
Vacuum Gage driving (mpg minded)
General discussion on Heat
T5 conversion
Problems Topics:
Ping/over heating
Dream:
What's your Future Dream Build
Vehicle Mods
Suspension and Steering Replace
65mustang-SOLD-200ci-t5-scarebird disks-vintage air ac-264/274 110 cam-mav 8inch 3.8 open-350cfm-CI headers
66 Bronco-SOLD-i6 170 - rust bucket never ran...
75 bronco-SOLD-v8 c4 dana 20 33's and disk brakes, locker front/rear.
MPGmustang
FSP Moderator
Re: My Mustang Saga
Post #2 by MPGmustang » Thu Nov 25, 2010 11:38 pm
I'm planning to go TBI with a 2bbl holley 670cfm, It's probably too much but I'd rather be over than under, this TB can support 125-275hp, I'm guessing with a 2bbl conversion the TB it will put me over ~140hp. right now, I think I'm hitting 90-100hp.
For the TB, I would like it to be a direct mount, as my head is mostly done to the extreme, I'll be using the same head.
I am planning this for summer 2011,
1) A Complete Suspension & Alignment (Priority)
2) a) Painless wire Kit
2) b) 130 amp 1 wire alt
2) c) Dual Electric Fans
3) Holley TBI kit (last)
Any Idea's/Concerns will be appreciated.
Thanks!
Richard
dagenham
Re: My Mustang Saga
Post #3 by dagenham » Sat Nov 27, 2010 10:51 am
The 670cfm sounds like way too much to me. It would be better to be smaller than too big. If you run too much cfm you can actually loose power. The rule of thumb I always heard is to take the cubic inches of the engine and double it to get the cfm's needed.
MPGmustang
FSP Moderator
Re: My Mustang Saga
Post #4 by MPGmustang » Sat Nov 27, 2010 1:53 pm
well done more research, you are right, I guess i've been stuck on the 670cfm TB as i have read somewhere some one got a 500cfm carb working perfectly, with mods to manythings to slow the gas consumption, and they got it running even better than a 350cfm.
http://falconperformance.sundog.net/compcalculator.asp
shows that if I had a perect head, the max the engine would pull would still be 354cfm, so a 400cfm TB would be perfect. I guess i have to face realistic facts. hopefully i'll get a reply soon from holley.
