1967 Mustang 6-200 with AutoLite 1100 1-V Carburator
J Thompson
Post #1 by J Thompson » Fri Dec 31, 2010 1:15 pm
My carb is missing the accelerating pump discharge weight (#95811 in my shop manual parts diagram) I am unable to locate a replacement at parts supplier or in any rebuild kit I have seen.
Carb is fine otherwise. Would appreciate suggestions I may have overlooked OR information I might use to fabricate a replacement.(ie: length, diameter, material). I'm thinking steel or brass
rod of proper length and approximate diameter of steel ball it rests on. Would appreciate your opinion and advice.
anotherhassel
Re: 1967 Mustang 6-200 with AutoLite 1100 1-V Carburator
Post #2 by anotherhassel » Fri Dec 31, 2010 9:04 pm
Hi i have no real info for you but this is kinda funny. My name is J Thompson as well lol. Always nice to see a fellow Thompson.
mysavioreigns
Post #3 by mysavioreigns » Thu Jan 27, 2011 3:42 pm
Hope you've found a solution by now, but if not, you might try looking for a junked 1100 1V carb at a junkyard or ebay - you don't necessarily need one in working condition or rebuilt.
I am kind of intrigued on why that part wasn't in your carb, lol.
Good luck.
1966 Mustang
Rebuilt 200ci, 1970 head, Duraspark II, Weber DGV, C4
Future/Underway Plans: All new suspension, T5 Transmission, 2V Conversion
J Thompson
Post #4 by J Thompson » Thu Jan 27, 2011 10:58 pm
Thanks for the response. The motor has been recently replaced and the carb had been rebuilt. Evidently somehow 2 of the 3 steel balls and the one weight were lost. I replaced the balls from a rebuild kit but could not find a weight. I had a response from a really helpful Mustang Man who sent me protographs of the balls and weights alongside a ruler with an estimate of the weight of the weight. I found one of my wife's knitting needles of comparable diameter to the weight, cut off a piece 9/16 " long and stuck it in the slot. Haven't had a chance to test it yet (it's at another location) but feel optimistic it will work. Will post results later in case anyone is interested.
Thanks for your interest.
