Shifter rod pics
paul25g
Shifter rod pics
Post #1 by paul25g » Fri Jul 01, 2011 11:20 am
Does anyone have a good pic of the shifter rods on a 2.77 three speed manual trans where they attach to the transmission. They were disconnected when I got this car and there were four shifter rods that came with the car. They're all a little different and am looking for a pic to see which two to use. Thanks!
Paul
paul25g
Re: Shifter rod pics
Post #2 by paul25g » Sat Jul 02, 2011 11:07 am
According to the Mustang parts manual, both shift rods for the 2.77 three speed trans have part number 7328. They look different in the manual and I know one has to be shorter than the other. Should these be the same part number or is this a mistake?
Of the four rods I have, two are short and two are long.
One of the short ones has a number stamped on it....C6ZA-7328-B. This should be the correct part for the shorter rod. The other short rod doesn't have a number stamped on it.
One of the long ones has a number stamped on it....C6ZA-7326-B. This looks similar to the longer rod in the parts manual except the 90 degree bend on the end where it attaches to the transmission is bent exactly opposite of the picture in the parts manual. The other long rod doesn't have a number stamped on it but it looks pretty much like the long rod with the number except the 90 degree bend is as shown in the parts manual.
Any ideas? If the long rod with the number isn't for the 2.77 three speed manual, any ideas what it's for? Thanks!
Paul
Post #3 by bubba22349 » Sat Jul 02, 2011 6:59 pm
Pictures of the parts would help. Have you tried the C6 rods on the trans?
paul25g
Post #4 by paul25g » Sun Jul 03, 2011 3:07 pm
I've got pics of the four rods, but not sure how to attach them, anyone know? Thanks!
Paul
Post #5 by bubba22349 » Sun Jul 03, 2011 9:06 pm
Have been using this one for posting pictures
http://imageshack.us/
You will find the info on posting pictures and the other different hosts you can use here
viewtopic.php?f=47&t=48863
paul25g
Post #6 by paul25g » Mon Jul 04, 2011 2:43 pm
Post #7 by bubba22349 » Mon Jul 04, 2011 5:09 pm
Well to me looks like the bottom set would be the right ones
