31st Mustang Ever Made
dudeigota66
Post #1 by dudeigota66 » Tue Sep 13, 2011 2:05 am
I found a local yard here in Cali with a man who says he has the 31st mustang ever!! The VIN matches!! Is this as amazing as i think it is?
66 Mustang with 68 200ci, Pertronix, All Else stock and C4- "Karen"
Does10s
FSP Moderator
Re: 31st Mustang Ever Made
Post #2 by Does10s » Tue Sep 13, 2011 10:24 am
My Brother in Law has a '64 Mustang with a D-code 289, 4 speed car that was built 4/09/64. It was the 6 thousandth something one made.
It was built before the 4/17 intoduction date.
But the 289 with a generator is the rare part!
Every early Mustang is worth a few bucks more for sure!
Later,
Will
'86 Mustang, Turbocharged, Best ET: 10.70@132.
'69 Mustang Sportsroof, 351w, auto
'63 Falcon, Turbocharged 250, C4, 9", Best ET: 10.64@127mph 11/21/14
mustang6
Post #3 by mustang6 » Tue Sep 13, 2011 2:13 pm
I read an article recently in one of the Mustang mags about the sequential VIN numbers not representing the ACTUAL number off the line since there were multiple factories, not all came off sequentially, etc. Still that is a very low number. That article did have some visual cues to watch out for that could help figure out if it was one the World's Fair cars or special demo cars so that could be really cool if it was special like that.
Scott
dagenham
Post #4 by dagenham » Tue Sep 13, 2011 8:55 pm
The last six numbers of the vin should be 100031.
Post #5 by bubba22349 » Thu Sep 15, 2011 11:13 pm
That is a true fact there where other cars with that same number except for being built at another factory (or assem. line) location :nod: Even so that would be a very early car :thumbup:
ski4evr
Post #6 by ski4evr » Sat Oct 08, 2011 7:22 am
Unfortunately, there is no way to tell what "#" Mustang you have or you come across. Ford started production of the Mustangs on March 9, 1964. They were built on the same assembly line as the Falcons. They shared the sequential numbers with the Falcons. There are no records that were kept by Ford. This has been discussed and researched by many. I have a 64 1/2 that was built on April 8, 1964. All I will ever know is that it was built in the first month. As to what "#"? No clue. If a guy is telling you that he has the "31st" Mustang made... He probably has some ocean front property in Arizona to sell, too. But... At a minimum, ask him to prove to you how he is coming to the conclusion that it's the # 31. Do not take it for face value.
64 1/2 Mustang Convertible
200 cid: '68 block, '66 head; Green Dot c4 Automatic; Pertronix II with Flamethrower II Coil; MSD6A
5 lug bolt pattern (V8 spindles and linkage; re-drilled axles and drums)
Front Disc; Rear Drum
