2018 Contributors:
Headers and dual exhaust
67drewstang
Post #1 by 67drewstang » Mon Jul 01, 2013 11:31 pm
I am gradually upgrading my 200 ci I-6 1967 Mustang convertible. Since the exhaust is starting to go, I am considering installing headers and dual exhaust.
Anyone want to advocate for any particular brand of header? How about exhaust arrangement? I am looking for a nice sound and am not afraid of a little exhaust noise, as long as it doesn't sound like a tractor....
Re: Headers and dual exhaust
Post #2 by bubba22349 » Tue Jul 02, 2013 12:09 am
Check out the C.I. Headers and exhaust systems :nod:
http://www.classicinlines.com/products.asp?cat=53
rbohm
Assistant Admin
Post #3 by rbohm » Tue Jul 02, 2013 1:51 pm
bubba22349 wrote:Check out the C.I. Headers and exhaust systems :nod:
8) seconded. mike has put a lot of time and effort into developing parts for our cars.
64 falcon
66 mustang
05 grand marquis
transient nodes of thought
of invention
65-coupe
Post #4 by 65-coupe » Tue Jul 02, 2013 2:37 pm
I have the 2" dual impostor stainless steel kit from Classic Inlines. Very nice had to modify some but that almost goes with everything.
1965 Mustang coupe, SPI Orange with custom TMI interior, 250 DUI, CI alum head ported, 274/274 110 Clay Smith cam, 1.65 roller rockers, Holley 390 4bbl, Lokar pedals and throttle calbe. Street or track front coilovers suspension, CI headers stainless with Jet-Hot ceramic coating, CI Stainless 2" impostor dual exhaust, 17x8 Coys C-67 wheels,
67drewstang
Post #5 by 67drewstang » Tue Jul 02, 2013 4:21 pm
Once I posted that question, I checked those out and they look nice.
Thanks for the responses.
66mustangdriver
Post #6 by 66mustangdriver » Sat Jul 27, 2013 5:12 pm
dual outlet headers and glasspacks. here is mine running the classic inlines set
http://www.youtube.com/watch?v=DhYIPRu1MD8
sound amazing and best quality builds available.
I make oil
Post #7 by I make oil » Sun Nov 17, 2013 8:39 am
I installed the SS header from mike and it sounds nice. Did have issues with the AC compressor mount, AC hisses and Alternator bracket. Not saying not to do it just be aware it requires some modifications. I still have not reconnected my AC. I need to have longer hoses made.
anotherhassel
Post #8 by anotherhassel » Sun Nov 17, 2013 3:07 pm
I have a cliffy header ,although I would use mike if I did It again, I also have flowmaster 40s. Take look on YouTube they sound awesome!
65-coupe
Post #9 by 65-coupe » Sun Nov 17, 2013 4:27 pm
I would get the headers and down pipes with a x pipe from CI. Then have a shop do the rest after you install them. I have the whole kit from CI and the fit is not great. I still have to go to a shop and have the rebend on e of the pipes and do new pipes from the muffle back so the tuck up better. Plus my Ceramic coating is flaking off. Sent Mike an email but have not heard anything back about it. I think I will pull the headers off and wrap them since the coating in coming off.
1966_l6
Post #10 by 1966_l6 » Wed Jan 08, 2014 4:50 am
I would like to put header this year , I have 66 block .
If I put CI header , do I have interference between header and starter ?
Can I modify Accelerator linkage ?
Fred
'66 L6 mustang A/T,P/S,A/C , DSII ,Weber 32/36 ,2.25" exaust line
http://www.flickr.com/photos/96174115@N07/sets/72157633985586643/
'52 Renault Colorale
65-coupe
Post #11 by 65-coupe » Wed Jan 08, 2014 12:42 pm
1966_l6 wrote:I would like to put header this year , I have 66 block .
I had no issues with the starter or alt. I have a 66 block.
1966_l6
Post #12 by 1966_l6 » Thu Jan 09, 2014 3:54 am
I read this CI page http://www.classicinlines.com/proddetail.asp?prod=FSP%2D200%2DDOP.
I don't know How I can see if my block is low mount or hight mount stater .
Fred
65-coupe
Post #13 by 65-coupe » Thu Jan 09, 2014 7:47 am
1966_l6 wrote:I read this CI page http://www.classicinlines.com/proddetail.asp?prod=FSP%2D200%2DDOP.
You should have a high mount. The starter at the top of the bellhousing
1966_l6
Post #14 by 1966_l6 » Fri Jan 10, 2014 2:07 am
Fred
66Sprinter
Post #15 by 66Sprinter » Fri Oct 10, 2014 10:14 pm
I put Mike's dual headers on a few years ago and switched to the 429 CJ starter (smaller body) and have no problems with fitment or access. I did my own exhaust adding an H pipe and then Borlas before finishing with dual exhausts. I have not had a single problem with the system since day one. (I did have a crack at the H pipe which I touched up this summer) Even with my T5, I have plenty of clearance. Once you loop over the tranny, its all standard V8 exhaust from there out to the back end.
IMHO its the best thing (cheapest) upgrade for running and performance that you can do for your car. At first I regretted not getting the chrome exhausts (trumpets) but since time soothes all wounds, I am better off without it. I have the backup lights and it would just be too busy back there. Jim :lol:
66 Sprint, rebuilt 200, 268 cam, dual roller chain, roller rockers, 3angle valve grind, 8.8 rear with 3.25, T5 and Torgue Thrust II's. Just right for the Mrs and Me to run from the empty nest.
wbstang
Post #16 by wbstang » Tue Apr 26, 2016 11:10 am
I'm running hooker headers to true dual flowmaster 40 mufflers and absolutely love it. There's a little bit of a drone once I'm going over 60 mph...but i like it :)
V8's are for vegetarians...
tom_66
Post #17 by tom_66 » Mon May 23, 2016 10:33 pm
My 66 Mustang has a 200ci stock engine. Installed a single header from cjpony parts and replaced the stock 1.75" exhaust pipe with a 2" pipe, and installed a flowmaster 40 muffler. Great sound at idle and low-mid rpms. However I noticed an annoying drone sound at mid and high rpms. I installed a resonator between muffler and tail pipe. Drone is gone. I might try a dynomax turbo muffler w/o the resonator in the next few weeks.
tom_66
Post #18 by tom_66 » Wed Jun 01, 2016 10:17 pm
I took my car to the muffler shop yesterday and installed true dual 1.75" exhaust pipes with 2 Flowmaster 40 and no resonator. The car has a nice rumble and sounds great, not too loud. It really sounds like a stock small block v8.
tom_66
Post #19 by tom_66 » Mon Jun 27, 2016 5:54 pm
I replaced the Flowmaster 40 with Flowmaster 50. The 50 is not too loud compared to the 40s.
My advice is: if you want an aggressive sound, then get a Flowmaster 40 (add a resonator to get rid of the drone at mid-high RPMs). If you want a mild sound (a little louder than stock, but not loud), get a Flowmaster 50.
Tom
