Rear frame rail replacement. Sanity Check...
1966Mustang
Administrator
Post #1 by 1966Mustang » Sun Dec 14, 2014 12:56 am
Ok, car is on jack stands and level at each end side to side, not front to back. I need to replace the rear frame rail upper sections, trunk floors and rear trunk support because they're rusted out. And the rear taillight panel because... at some point the car was hit on the DS rear and the repair was pretty crappy. The rear bumper was shimmed out with lug nuts... anyway... bad bad bad. Passenger side frame rail looks like swiss cheese.
My plan for restablishing all this with a plumb bob is...
Drop a plumb bob from the front lower control arm mount points, draw a line between the points.
Drop a point from the front leaf spring holes and draw a line between those points... frame side.
Drop a point from the existing rear shackle mount points, draw a line between those.
Establish a centerline from the lower radiator support all the way to the back of the car.
Get the centers of the spring perches off the axle, make sure all the centers are in agreement.
Then make some sort of jig...
Get some square tubing (maybe unistrut) and attach through the front leaf spring mounts on each side past the rear on each side. Attach a cross brace someplace connecting each side and square the unistrut brace up. Add a brace from the unistrut up to the axle snubber plate so it doesn't move. This should stay relative to the framerails. I should be able to establish the heights and mount points from the old to put the new pieces back where they belong.
Kinda like this...
http://4.bp.blogspot.com/_23Tu1EcVfgc/T ... 0_2505.JPG
Found here..
http://dougs65mustangrestoration.blogsp ... chive.html
Anyone see any issues with what I have planned?
Thanks!
Perry
'65 Mustang Coupe, C4, DUI, CompCams 260, Addco 1", StreetOrTrack Front Bilstein Coilover System, Bilstein Rear Shocks, 4-1/2 leaf springs.
Support our forum:
Like us on Facebook, watch us on YouTube, Buy FordSix Gear , Make a Donation!
Re: Rear frame rail replacement. Sanity Check...
Post #2 by bubba22349 » Sun Dec 14, 2014 11:15 am
Sounds like you have a very good plan, here are few suggestions that maybe of help. The car should also be level front to back as well as side to side you can use the door sill or rocker, and or the bottom of front and rear frame (torque boxes) sections with the car level in two directions then the plumb bob points will be more accurate (vertically plumb too). Next check (and it's very important) that the frame is still square. I do some diagonal measurements of the front frame section (you can use some matching factory mounts or holes), next do the rear section of frame, and last a measurement of the whole frame from a front to rear point. If the car is still square your good to go if not you will need to use a porta power or jack to square it up (within a 1/4 inch is ok less is better yet). If your doors line up nice you could weld in some temp bracing 1 inch square tube works well in an X to help keep the body shell from moving around. Depending on if the rear frame rails have any strength left sometimes it's easier to do one side at a time. You might consider putting in a set of temp or permanent sub frame connectors to help it all stay in position. Good luck on the rebuild. :nod:
1966Mustang
Administrator
Post #3 by 1966Mustang » Mon Dec 15, 2014 12:14 am
Thanks Bubba. I'll do all that you suggest. For right now it looks like the rear quarters and wheelhousings are staying on, so I'll run bracing the cut stuff. Doors are still on and doesn't look like the gap moved at all when I was putting it on stands.
Good suggestion on the subframe connectors. Thats something I want to do anyway, might as well do that now.
-Perry
Support our forum:
DannyG
Post #4 by DannyG » Fri Jul 07, 2017 10:25 am
Dragging this back from the past, how did that frame rail job go for you ?
Any advice or lessons learned along the way ?
DannyG
C8 block, .040 over, zero decked. Forged Racetec pistons , D7 large log head .9:4 compression, CSC 264-112 cam going in a '65 Mustang one day...
1966Mustang
Administrator
Post #5 by 1966Mustang » Sat Jul 29, 2017 4:22 pm
Hello,
I thought this post looked familiar!
I pretty much did what I said I was going to do, (and followed bubba's suggestions) although I'm sure there are better ways to do it. The Jig I made worked pretty well as far as keeping things in relation to the relevant points for the leaf springs. If I HAD to do it over again, I would have gone with the full-length frame rails, which would have lead to a new floor most likely. Also, get the best quality rear lower trunk cross member you can find. The frame rails were actually the easy part, just take your time and measure measure measure as much as you can.
That said, the car sits straight, the trunk is solid and the rear taillight panel is fitted to where it needs to go. I will see if I have any pictures handy of the work while it was happening.
There is still much to be done though. I actually need to weld in that rear taillight panel, finish fitting and welding both sides quarter panel skins and outer wheelhouses.
I'm not working on it as vigorously as I would like - just because. Maybe all of the fordsixers can come pay me a visit and get r done. Like a barn raising! :beer:
- Perry
Support our forum:
DannyG
Post #6 by DannyG » Sat Jul 29, 2017 11:05 pm
Thanks Perry.
I just leveled the car today, and pulled the springs and rearend.
All the nuts and bolts had neversieze on them, some previous owner must have done work back there. Every bolt came out with no trouble at all. Even the front spring hangar bolts came out by hand after loosening them !
I'll start measuring tomorrow...
DannyG
1966Mustang
Administrator
Post #7 by 1966Mustang » Sun Jul 30, 2017 11:09 am
The neverseize was a good idea, too bad they didn't use any neverrust! :D I had to sawzall my front bolts.
The rust was *REALLY* Bad... I think this was the good side.
Support our forum:
1966Mustang
Administrator
Post #8 by 1966Mustang » Sun Jul 30, 2017 11:26 am
Support our forum:
1966Mustang
Administrator
Post #9 by 1966Mustang » Sun Jul 30, 2017 11:35 am
Support our forum:
1966Mustang
Administrator
Post #10 by 1966Mustang » Sun Jul 30, 2017 12:10 pm
I opted to screw in the tailight panel for now to have some adjustability options. Do NOT use self-tapping sheemetal screws. There are 1/8" sheetmetal screws that hold much better, but you have to drill a pilot. Or use Cleco's... like a professional. I use screws...
At some point I sectioned in the outer-wheehouse. I only removed what was rusted out of the old part. I think if I removed the whole outer I would be hating life. I didn't want to mess with that welded flange. I don't think that's spot welded but more of a seam weld the whole length. I tried to overlap the 2 pieces and cut them together with a pnuematic body saw. Make sure you have a decent body saw that won't vibrate apart... The electric body saw from HF is total junk... their pneumatic saw is less junky in my experience.
Right now I have the quarter skin fitted and screwed in a couple places. The wheel arch fits pretty well and I've got the rear corner cap aligned with everything - You need to fit quarter skin to the rear corner cap curve - i.e. don't just jam the quarter skin flange to it's full depth against the taillight flange area. (if you're replacing to that rear flange) - you'll need some adjustment in/out unless you plan on using an 1/8" of filler to match that curve back up with your taillight panel corner caps.
I've been waffling on having to prime/paint those areas that won't be accessible. I just need to go do it.
Thanks,
Perry
Support our forum:
ludwig
Post #11 by ludwig » Sun Jul 30, 2017 2:59 pm
Props to you, brother!!! Chip Foose has a dozen guys doing that same thing on one car!
1966Mustang
Administrator
Post #12 by 1966Mustang » Sun Jul 30, 2017 4:19 pm
HA! I'm sure I couldn't fit 12 guys in my garage without encroaching on customary personal space norms. If they could get it done in 1 hour I would just excuse myself and watch with a beer in hand.
Also - DannyG - inspect the frame rails you're installing and improve the welding around the rear bushing mounts if needed. Mine didn't look as good as I thought they should. It is doubtful these things go through any rigorous QA over in the R.O.C. or wherever they're made.
Thanks,
Perry
Support our forum:
1966Mustang
Administrator
Post #13 by 1966Mustang » Wed Aug 02, 2017 9:13 am
This is basically what I built for installing/aligning my rear framerail sections. Seemed like a sound plan at the time.
Support our forum:
Post #14 by bubba22349 » Wed Aug 02, 2017 9:54 pm
:beer: very nice work Perry, that 1966 Mustang should turn into a great driver! :nod: :thumbup:
Users browsing this forum: No registered users and 8 guests
