200ci Mustang 66 ignition/carb question
Re: 200ci Mustang 66 ignition/carb question
Post #51 by bubba22349 » Sun Nov 01, 2015 4:24 pm
Right if you go with a Groupe 24F you will need to use the original type battery tray. Like I mentioned though before a regular Groupe 24 battery also fits is the same size only difference is that the position of the Pos. and Neg. battery posts are reversed, and you only need to have a little different lenght of Pos battery cable to Solenoid. Good luck :nod:
