2018 Contributors:
ball joints
mluck
ball joints
Post #1 by mluck » Tue Oct 20, 2015 3:24 pm
has anyone replaced there upper and lower ball joints on there 67 mustang...now looking for parts its asking 3 or 4 bolt....what does a 67 have...
67 mustang 200ci. offy with 3 webers,260 cam,coated duel header,duel timing chain,mallory unilite with a hyfire 6a,alum. finned edelbrock valve cover and 3.20 gears.
Re: ball joints
Post #2 by bubba22349 » Tue Oct 20, 2015 5:39 pm
All the 67 Mustangs that I have ever worked had the 4 hole riveted original ball joints or the bolted on replacements. To my knowledge only the very early Falcons and Comets (1960 and part of 61) had the 3 bolt type. Good luck :nod:
mluck
Re: ball joints
Post #3 by mluck » Tue Oct 20, 2015 7:23 pm
thank you
Re: ball joints
Post #4 by bubba22349 » Tue Oct 20, 2015 7:45 pm
Your welcome but you should really check yours out first though, just in case if it has already had a set replacement aftermarket control arms installed in the past. Good luck :nod:
CoupeBoy
Re: ball joints
Post #5 by CoupeBoy » Wed Oct 21, 2015 1:02 pm
The lower balljoints are replaced by replacing the entire control arm.
New bushing, stamped arm, and balljoint all in one.. usually about $25/each.
rbohm
Assistant Admin
Re: ball joints
Post #6 by rbohm » Fri Oct 23, 2015 5:17 pm
mluck wrote:has anyone replaced there upper and lower ball joints on there 67 mustang...now looking for parts its asking 3 or 4 bolt....what does a 67 have...
67s can have either one, however they are most likely 4 bolt joints. as noted check to be sure first, its easy enough just count the rivits.
64 falcon
66 mustang
05 grand marquis
transient nodes of thought
of invention
sixty6
Re: ball joints
Post #7 by sixty6 » Tue Oct 27, 2015 6:57 pm
Recently I have replaced upped ball joint on '66. It had 4 bolt one. The one I removed was replaced by previous owner not that long ago by cheap ones. I went with Moog brand this time, I think it should last longer, will see.
Mustang '66 coupe 200ci T5
jdn21758
Re: ball joints
Post #8 by jdn21758 » Wed Oct 28, 2015 2:12 pm
i have renew the lower balljoints but rebuild it complete its easyer to do,,
greetzzz JD,,,,
