anyone know the size to automate brass carb fitting for vacuum advance?
HondaSL
Post #1 by HondaSL » Wed Mar 21, 2018 12:55 am
Got a 1966 stang 6-cylinder & i am missing the brass fitting that the vacuum hardline flared end plugs into-which plugs into the carb body.
Does anyone know the size so i can buy one on amazon/ebay/pepBoys? & what it would be called to normal people (like 'flared coupler' or something)
In the pic part fiche, it is names 'Distributer Vacuum Adapter' FordMoCo part # 358165-S in the lower RH corner area. Or circled in pink on the engine pic of a car which does have it correct.
Thanks a ton for the expertise & insights!
Re: anyone know the size to automate brass carb fitting for vacuum advance?
Post #2 by bubba22349 » Mon May 21, 2018 4:08 pm
HondaSL wrote:Got a 1966 stang 6-cylinder & i am missing the brass fitting that the vacuum hardline flared end plugs into-which plugs into the carb body.
The vacuum line fitting is a tapered compression fitting, so the other end in the carb to my best guess is that it's a tapered compression fitting adapter. These fittings are also commonly used on a gas water heater too so you should be able to fine them at a good auto parts store like NAPA or at a hardware store such as Home Depot. Good luck :thumbup: :nod:
HondaSL
Post #3 by HondaSL » Wed Nov 07, 2018 10:33 pm
In case anyone ever needs an answer:
3/16" Hex Head Plug with an inverted flare
Dorman part number 785-450
