Tranny Swap Question???
pedal2themetal45
Post #1 by pedal2themetal45 » Tue Aug 07, 2007 3:43 pm
Hi all
I posted this in the Dirve train forum with NO reply for 2 days now.
Sorry if this has been mentioned before I'm no good on the search thing. Right now I have a 3spd out of a 72 Maveric in my comet W/200cu.. but I am thinking of a 4 or 5 speed for it.. is there a direct swap tranny out there? I believe it has the duel patteren Bell.
Tim
the pic links work now. 11/03/06
61 Comet W/200
http://s82.photobucket.com/user/pedal2t ... ort=6&o=12
64 International 4dr. truck w/466
http://s82.photobucket.com/user/pedal2t ... ort=6&o=23
wallaka
Post #2 by wallaka » Wed Aug 08, 2007 12:52 am
An SROD will go anywhere a 3.03 will. Same everything, according to SR's post in the Drivetrain section. A T4 might as well, with the right bellhousing. Anything else requres an adaptor. Then again, an adapter is a hunnerd bucks or so, or you can fab your own. There are plans somewhere in the Drivetrain section.
I don't think it was posted to your question, but there is another one up near the top of the page that is similar.
SROD=4 speed w/OD, in case you were wondering.
Down to 29 cylinders!
2006 Porsche Cayman H6, 1968 Mercury Monterey big block (390), 1967 F-100 240, 1965 Mercury Comet 404 (200), 2009 Triumph Street Triple
pedal2themetal45
Post #3 by pedal2themetal45 » Wed Aug 08, 2007 4:29 pm
I believe I have the duel pattern bell so does anyone know if a T4 or a T5 bolt up?
Tim
61 Comet W/200
addo
Post #4 by addo » Wed Aug 08, 2007 6:15 pm
Pretty sure you still need an adaptor plate. There's the rare T-45 bell, and you should grab one at any price up to (say) $400 as it will be a straight bolt-up. All you then need to fabricate is the rear crossmember.
pedal2themetal45
Post #5 by pedal2themetal45 » Thu Aug 09, 2007 9:08 am
OK
Thanks guys
tim
61 Comet W/200
hotrodbob
Post #6 by hotrodbob » Fri May 16, 2008 1:13 am
T-5 will require an adapter and machining of the front bearing cover. 4 speed will bolt up
Hotrodbob
http://bob-beck-motorsportsannouncing.com/
http://gotgaas.com/home.html
Anyone can restore a car, it takes a real hotrodder to cut one up and make it cool.
powerband
FSP Moderator
Re: Tranny Swap Question???
Post #7 by powerband » Fri May 16, 2008 9:31 am
" Everything in my garage has a story ..."
