hole in hood
250coupe
hole in hood
Post #1 by 250coupe » Thu Apr 24, 2008 11:10 am
has any one put a 2bbl weber on there car using a clifford adaptor with out cutting a hole in the hood. i have a 250 in my mave and i think im going to have to cut a hole in mine when i install mine.
1974 maverick (1970 clone) W/ 250I6
sp_alloy_head
Post #2 by sp_alloy_head » Mon Apr 28, 2008 3:45 pm
http://usera.imagecave.com/63comet/100_0058.jpg (the image is huge)
Then read THIS thread by 63Comet, he mounted a weber 38/38 directly on the log.
Gene Fiore
RC Moderator
Post #3 by Gene Fiore » Mon Apr 28, 2008 4:11 pm
That's a pic of a direct mount setup...no adaptor to speak of. This setup on a Maverick will fit under the stock hood. I've never seen one using the 2 into 1 adaptor not require cutting the hood.
1971 Maverick, 250I6, crank knife-edged, Clay Smith 278 solid cam, .040 over 255 V8 pistons, 10.5 to 1, Custom 500 Holley 2V on Classic Inlines Aluminum cylinder head, 1.6 rockers, Hooker header, DUI dizzy, C-4 w/2800 stall, 8" 3.55 det locker
Best ET 1/4 mile: 14.92 at 89.61 mph on 1/12/2013
My Classic Inlines Photo Page
63comet
Post #4 by 63comet » Mon Apr 28, 2008 4:31 pm
I actually had a H/W 5200 mounted on an adapter from stovebolt originally on the log head. It fit with no problem on my 200 BB. I had pics, but I deleted them when I installed it directly to the log.
1963 Comet tudor with a 250 that has 255 v8 pistons, clifford cam 264*, clifford dual outlet headers with dual 2" exhaust thru glasspack turbo mufflers, mildly ported head with a Weber 38dgas directly mounted on intake log, and DII dizzy and MSD6AL ignition. C4 auto that has been rebuilt .
Gene Fiore
RC Moderator
Post #5 by Gene Fiore » Mon Apr 28, 2008 4:43 pm
63comet wrote:I actually had a H/W 5200 mounted on an adapter from stovebolt originally on the log head. It fit with no problem on my 200 BB. I had pics, but I deleted them when I installed it directly to the log.
The 200 is not as tall as the 250, thus the problem with hood clearance when using an adaptor with the 250 motor.
250mav
Post #6 by 250mav » Mon Apr 28, 2008 6:43 pm
if you did a droped air cleaner i could see it working. maybe some kinda cold air tube if your not afraid to look too rice lol
1976 Ford Maverick
6xCylinders+2xBarrels
~Tony M.
http://www.cardomain.com/ride/2422769
