2018 Contributors:
Airfilter..
mavchick
Airfilter..
Post #1 by mavchick » Thu Jun 12, 2008 3:23 pm
I'm thinking about buying this air filter off the ford six parts website..
Has anyone used this yet?
http://www.classicinlines.com/proddetai ... AIR&cat=68
I'm also thinking about getting a dress up package. But I don't need the valve cover because I already have one.
What do you think?
http://www.classicinlines.com/proddetai ... DUP&cat=68
here is under my hood.. I really want an aluminum radiator too.
Gene Fiore
RC Moderator
Post #2 by Gene Fiore » Thu Jun 12, 2008 6:03 pm
The dress up kit is nice, but neither one of the air cleaners will fit your stock one barrel carb. They are designed for 2 barrel or 4 barrel carbs. :wink:
1971 Maverick, 250I6, crank knife-edged, Clay Smith 278 solid cam, .040 over 255 V8 pistons, 10.5 to 1, Custom 500 Holley 2V on Classic Inlines Aluminum cylinder head, 1.6 rockers, Hooker header, DUI dizzy, C-4 w/2800 stall, 8" 3.55 det locker
Best ET 1/4 mile: 14.92 at 89.61 mph on 1/12/2013
My Classic Inlines Photo Page
mavchick
Post #3 by mavchick » Fri Jun 13, 2008 12:18 am
Gene Fiore wrote:The dress up kit is nice, but neither one of the air cleaners will fit your stock one barrel carb. They are designed for 2 barrel or 4 barrel carbs. :wink:
Aww that stinks! Thanks for telling me before I bought it.
Can you recommend any nice ones? I can't seem to find one.
Perhaps I should just switch to a two barrel carb?
I also made the mistake of putting a Mustang valve cover on mine, but I made it work.
Gene Fiore
RC Moderator
Post #4 by Gene Fiore » Fri Jun 13, 2008 7:53 pm
I got this one from Mustang's Unlimited, but I had to modify it to make it fit. The opening in the base for the carb was too small...but I was able to make it work. :wink:
http://mustangsunlimited.com/itemdy00.asp?T1=AC3+01
mavchick
Post #5 by mavchick » Sat Jun 14, 2008 4:37 pm
Gene Fiore wrote:I got this one from Mustang's Unlimited, but I had to modify it to make it fit. The opening in the base for the carb was too small...but I was able to make it work. :wink:
huum thanks!
250coupe
Post #6 by 250coupe » Thu Oct 09, 2008 11:44 am
Check out autokrafters. call them and get them to send u a parts book they have chrome aircleaner kits that will fit your 1bbl
1974 maverick (1970 clone) W/ 250I6
