2018 Contributors:
ground strap question
1974 maverick boy
New Member
Post #1 by 1974 maverick boy » Thu Oct 15, 2009 3:47 pm
I have a 74 with the 200 6cyl and it didn't have the ground strap on it and don't see where it goes so i can get one on it can anyone help please?
Gene Fiore
RC Moderator
Re: ground strap question
Post #2 by Gene Fiore » Thu Oct 15, 2009 5:27 pm
If you're talking about the ground cable from the negative side of the battery, there's either a spot on the passenger side of the block where you can bolt it to or use one of the mounting bolts for the alternator bracket. :wink:
1971 Maverick, 250I6, crank knife-edged, Clay Smith 278 solid cam, .040 over 255 V8 pistons, 10.5 to 1, Custom 500 Holley 2V on Classic Inlines Aluminum cylinder head, 1.6 rockers, Hooker header, DUI dizzy, C-4 w/2800 stall, 8" 3.55 det locker
Best ET 1/4 mile: 14.92 at 89.61 mph on 1/12/2013
My Classic Inlines Photo Page
1974 maverick boy
New Member
Post #3 by 1974 maverick boy » Thu Oct 15, 2009 5:57 pm
the ground strap i am taking about is the one going from motor and or tranny to fire wall on alot of rigs . when i got this car there wasn't one on it and i dont see where it is should go.
Gene Fiore
RC Moderator
Post #4 by Gene Fiore » Thu Oct 15, 2009 6:03 pm
I know of no such strap on my Maverick and I've been over every inch of this car...well, just about!
kukm66
Post #5 by kukm66 » Sun Oct 25, 2009 6:06 am
On the Falcons, it hooked to your exhaust bolt and then to the area around the heater motor.
1964 Falcon Futura Convertible
1964 Ranchero
JackFish
Post #6 by JackFish » Sun Oct 25, 2009 11:17 am
There is a bolt hole in the back of the block for a ground strap that goes up to the firewall on my '78.
Yup, I bought another one.
1996 Chevy Caprice 9C1 (3)
1999 Dodge Ram 2500
Crosley
Post #7 by Crosley » Sun Oct 25, 2009 3:52 pm
any clean spot from the body shell to the engine is good. Grounds are very important
Tony in AZ...
"130 mph is known as first gear at the Bonneville Salt Flats"
wallaka
Post #8 by wallaka » Wed Oct 28, 2009 9:50 am
Mine goes from a starter bolt to the firewall.
Down to 29 cylinders!
2006 Porsche Cayman H6, 1968 Mercury Monterey big block (390), 1967 F-100 240, 1965 Mercury Comet 404 (200), 2009 Triumph Street Triple
