David_Conwill
Okay, kind of a weird question. Ordinarily I wouldn't consider this much of a hot rod motor, but it's a nostalgia thing because they were made in my hometown (Whitehall is about 10 minutes north of Muskegon). Can anybody tell me if the Red Seal motors they were using in the twenties were different from the Continental inline sixers they used in the Kaiser and Frazer? Beyond that, how different are the industrial engines? Does anybody know if cylinder heads, intakes, camshafts and the like will interchange between the passenger car and industrial eninges?
I only ask because it's more than likely I'll be able to find a Red Seal industrial engine somewhere, but it would be cool to find the "experimental" Edmunds head that was available for the Kaiser Darrin or the 2 carb intake that they produced for the taxicabs and be able to bolt it up without having to hold out for a take-out from a K-F.
I appreciate any help, there is minimal history on Continental Motors available online and nearly zero technical history of the engines themselves. I have a sneaking suspicion that the Red Seal name was used on a lot of engines and that the Durant, Star, et al engines probably don't interchange with the 1940s and '50s industrial motors, and that the K-F engine may be a different beast entirely, but there just isn't enough info out there to know anything for sure.
Thanks,
Dave
Thanks,
Dave
