1984 Ford 2.3L powered Bronco II
chad
Re: 1984 Ford 2.3L powered Bronco II
Post #101 by chad » Sun Dec 06, 2015 11:53 am
"I wish I had a unibody…."
Oh, cool!
I 4got, Ranger biased, a pick up. I wuz thinkin most of the '80s meant a sedan based rig. I remember them as aa guy at work had one. I think the motor worked out to the same as my 170 ci if doing the math on the liter conversion to ci.
Can U get / would one B interested in - a 411 rear?
Lockers, hi steer or any of the other stuff?
Sure seems like ur gettin together a excellent motor.
MechRick
Post #102 by MechRick » Sun Dec 06, 2015 3:01 pm
I don't plan on lifting it at all. I don't want the MPG to go backward.
There was a limited slip BII in the wrecking yard I was going to grab the carrier out of but I missed it.
The 3.45 ratio seems to be perfect for the tire size/HP.
If I ever break the 7.5" diff I might go to a 8.8" with 3.55's, but I'm cautious about changes that will impact fuel economy. Last tank was 21 mpg, with most of it work commute.
chad wrote:Sure seems like ur gettin together a excellent motor.
It's a happy engine. Still tweaking the jetting. Soon as I get it dialed I'll post the final specs on the 32/36.
Stock cam, aluminum cam gear
chad
Post #103 by chad » Sun Dec 06, 2015 5:55 pm
great carb, doesn't seem 2 B anything else like it 4 this range displacement. Glad U dumped the other.
Is this what I'd call a square motor? (bore/stroke)
Thanks for bringin me along as you've gone thru this!
Keep us informed.
BTW: that's not the motor that went fwd, rwd and 4wd is it?
I know that 1's a ford/mutsub. But not titled 'lima', eh?
NA, turbo, and efi too I think. Not sure on yrs/models...
MechRick
Post #104 by MechRick » Mon Dec 07, 2015 12:01 am
chad wrote:Is this what I'd call a square motor? (bore/stroke)
3.780" bore by 3.126" stroke. Decidedly oversquare.
chad wrote:that's not the motor that went fwd, rwd and 4wd is it?
AFAIK, it never went front drive.
chad wrote:I know that 1's a ford/mutsub. But not titled 'lima', eh?
It is the Lima.
chad wrote:NA, turbo, and efi too I think. Not sure on yrs/models...
The first year I remember was 1974, in the Pinto. It was the replacement for the German 2.0L. They were stock in many other cars. Mustang/Capri, Fairmont, Merkur, Thunderbird/Cougar, Ranger, Courier, Aerostar. It was also used in boats, with Cobra outdrives.
chad
Post #105 by chad » Mon Dec 07, 2015 12:23 pm
I think the one I mean is a different 2L (2.0 - 2.9). It's been mounted transverse too.
Mighta been mazda (rather than mitsub) as well as Ford, no matter -
hot lill rig for your locale!
nice balance to the p/u,
what more could you need?
(cycles 'n boats I guess?)
MechRick
Post #106 by MechRick » Mon Jan 18, 2016 11:37 pm
Finished the light bar.
Gave the hitch a stress test. I wouldn't want to use this vehicle to tow something this heavy (3k). It would be torture.
Started working on some audio. Installed Pyle 4" speakers in the dash, and will install 6"x9" in the rear. The rear speakers in the BII face each other, the absolute worst situation for audio. Facing forward or even up would have been better, but in the interest of simplicity, I made some wedges from 2"x8" to angle them up slightly. Not much room in a BII for speakers.
Head unit is a $40 Dual Multimedia unit with no CD changer.
chad
Post #107 by chad » Tue Jan 19, 2016 12:44 am
2.0, 2.3, 2.5 are all "Lima"?
R VTech & Duratec Lima's?
How can I ID if my Focus (2.3) is this motor?
How can I ID the right donor for the better head?
MechRick
Post #108 by MechRick » Tue Jan 19, 2016 3:09 pm
2.0 and 2.5 (Ranger only), and 2.3 Lima were SOHC.
If you have a 2.3 in a Focus you have a Duratec.
Focus also used the Zetec, but only the 2.0L version, unless you lived in Europe...
chad
Post #109 by chad » Tue Jan 19, 2016 8:36 pm
Thank you, that's helpful.
There seem to be two 2001 Focus motors - mine has Ztec on the valve cover and parts ordered for the 2.3 are appropriate (by vin #) and I think they said a DOHC. I thought the other model listed for it was 2.1 but am uncertain as it's not mine/I don't follow it (may B a SOHC as well). I will go to "the Ranger Station" on-line as that's the only place I've found info on these guys. Oh, wait - there's 2 "Focus" sites but not as helpful technically.
As the body goes I will now (from your enthusiasm/write up) try to grab the engine for another project. Can U tell me again which head is most desirable? I think U mentioned a D shaped exhaust port (not oval or round)? Is that the only thing to look for? What yr./make/model is the donor?
MechRick
Post #110 by MechRick » Tue Jan 19, 2016 11:06 pm
The zetecs are good engines. If yours is in a Focus, it should be a 2.0L. They share the bellhousing with the cvh and the old 2.0L german four. They were all DOHC, cast iron block and aluminum head.
The Duratecs were either 2.0L or 2.3L. They also are all DOHC, but aluminum block aluminum head, with a unique bellhousing pattern.
The Limas are cast iron block and head, SOHC, and share nothing with zetecs and Duratecs.
All the exhaust ports on the Lima heads are the same, it's the intake ports that change. I feel the D port heads run the best of all (1983-1989 cars).
chad
Post #111 by chad » Wed Jan 20, 2016 8:37 am
"...share nothing…"
OK , still workin this out - mine's not a Lima (but a milwakie or wherever it was made) then.
MechRick
Post #112 by MechRick » Wed Jan 20, 2016 5:16 pm
The Zetecs were a Ford of Europe product. Popular in the UK, and came in a multitude of displacements. They can make 200 hp with bolt-ons. The first ones I saw were in the Ford Contour (which was a Ford of Europe vehicle, aka 'world car').
The Duratecs were a joint Ford/Mazda design supposedly with a bit of Cosworth influence (http://www.cosworth.com/products/crate- ... omponents/) .
The Lima engines were cast in either Lima Ohio or Taubate, Brazil.
chad
Post #113 by chad » Thu Jan 21, 2016 7:57 pm
brazil - no wonder i c them in jeeps etc down there.
nother member here just posted pm 2 me of donors but he didn't put on yrs. of each model.
he's got 1 in a 60s 'stang!
i'd like to efi turbo 4WD bio diesel one but don't think that diesel is such a good idea (for the motor - hi compression, design, etc)
I bet - if I saw one (the Brazilian Jeep) - I could have my friend make the motor/transfer adapter for it!
I like ur story bout the 'vett that showed up (or should I say got "shown up")?
MechRick
Post #114 by MechRick » Tue Mar 29, 2016 6:13 pm
Just as an update on the Weber jetting, I'm currently running primary main 145, secondary main 150, primary air corrector 150, secondary air corrector 160, idle jet 50.
Still not happy with it. It's rich at cruise (12-13:1), leans out to 14:1 at moderate throttle right before the power valve kicks in. I can't tell if it's an emulsion tube problem (did switch to an F6, same problem), or caused by too much overlap of the high speed idle circuit and the main circuit. I can fix it with leaner jets and air correctors, but then it's dangerously lean at moderate throttle (16.5:1).
I might try drilling out the idle air bleeds, but I think EFI may be around the corner...
MechRick
Post #115 by MechRick » Tue Mar 29, 2016 6:37 pm
Did manage to get a compressor mounted and the rest of the parts for A/C...
Blows super cold.
chad
Post #116 by chad » Tue Mar 29, 2016 8:34 pm
MechRick wrote:Just as an update on the Weber jetting, I'm currently running primary mai...
Still not happy with it...
Untill then -
U git the pinto motor, Y not the weber it came w/? (32/36) and the jets used? Too much weight increase w/the BII?
(What transmis U put in? rear gear? tire sz? - I 4got).
MechRick
Post #117 by MechRick » Wed Mar 30, 2016 11:39 am
The Weber I have is a replacement carb off a Jeep. Carbs around here are pretty much unobtainium, especially ones off 40 year old Ford economy cars. I would love to know what emulsion tubes were used in the Holley 5200 (weber clone).
I do have a Motorcraft 2bbl bolted to another vehicle I can try, if I want.
chad
Post #118 by chad » Thu Mar 31, 2016 11:13 am
some over on the "144 - 250 Sm Block Performance" forum on this site have been successful trading, e-baying, on-line accessing (USA carb rebuilders/sales) these carbs. One guy is very knowledgable (from down under - I think he's frm NZ) on these Webers (all models of them). He can tell Weber yrs/makes from Spain, USA, Italy, etc. Xctasy is the 'handel'. Pretty helpful 2 me/many others. A PM would B fine or post a new thread on that forum. I'm sure they would be interested in coming over to see this one if they havent yet...
MechRick
Post #119 by MechRick » Mon May 09, 2016 5:06 pm
Well, I attempted to bolt the 2100 on this thing, and the electric choke cap wants to occupy the same space as the valve cover. Seems I knew this, and forgot it. Classic case of CRS.
The roundy-round guys would just ditch the choke, and it would work.
I'm reaching the end of experimentation on this thing. I've got a better daily driver getting 34 mpg, and my next project is going to be a Locost 7. I'm going to use this engine, since I'm not entirely satisfied with the power to weight ratio of the BII.
Another engine will go in the Bronco II in the near future, probably a pushrod 4.0L or a 302. But I really would like to find a small diesel to swap in.
I'll play with the four a bit before taking it out. The 2100 will drop right on, choke cap and all, if I use a 2bbl adapter on the lower half of an EFI intake.
http://www.racerwalsh.zoovy.com/product ... 1232B.html
This and a mild Crane cam will go in, to see what kind of HP level I can get out of it before I borrow it for the Locost 7.
chad
Post #120 by chad » Mon May 09, 2016 9:46 pm
I know they masage the bottom of the A/C base w/a hammer 4 the ford6 to fit that part. Never new a 4 V/C would get in the way…
MechRick
Post #121 by MechRick » Mon Dec 19, 2016 12:43 am
Finally some updates on the Bronco. Updated the fuel system to an in tank pump (1990 Bronco II) and installed a Megasquirt 1.
Newer pump/sender fits perfectly, eliminates the dual pump setup of the older ones, and creates a problem. Apparently the newer senders use a different resistance scheme that is also inverted. Fuel gauge now reads backward, running out at about 3/4 tank. At least its predictable.
Inside of the tank is clean.
Surprisingly, Ford never made a supply line that was 3/8" all the way to the fuel rail. I found a filter that was 3/8" on both ends, but had to make a fitting to adapt the 3/8" lines/fittings to the fuel rail.
MechRick
Post #122 by MechRick » Mon Dec 19, 2016 1:07 am
I used the Dorman tool to press together fittings and lines, and snapped everything together.
I put the same computer controlled carb harness I took out back in, after the necessary re-pinning for F.I. The Megasquirt mounted nicely on the passenger kick panel with a D.I.Y. 60 pin adapter.
Note the duct tape coupling the tube to the throttle body. Still searching for 2.5" rubber tubing.
I had a problem getting the Ford IAC to work. Spent a bunch of time tracing wires, checking circuits inside the MS1, but it ended up being a firmware bug. Changed the idle option to closed loop, and then back to warmup, and started getting a square wave out of the fidle pin.
Tune time. It will take a couple days to get it close.
I'll post driving impressions after a few days...
Post #123 by bubba22349 » Mon Dec 19, 2016 1:04 pm
:hmmm: that should give you a bit more bottom end torque with the EFI system. Any plans for a Turbo on it? Good luck :nod:
MechRick
Post #124 by MechRick » Mon Dec 19, 2016 6:11 pm
If I stumble across an ihirb52 turbo, or perhaps a T3 Garrett, or one of the cast off Subaru turbos (assuming one would work, not sure on the sizing), I might spend the time welding up the custom header required to clear the evaporator plenum. Dished Speed Pro pistons are available so I think I could just swap my rings over. And I would need bigger injectors, the ones I'm using now are 22 lb/hr four-hole Denso units out of a D*dge...
So yes, I've given it some thought. :D
You are right. The long runner EFI is worth a few ft-lbs down low...
MechRick
Post #125 by MechRick » Tue Dec 27, 2016 5:54 pm
While tuning, I noticed some abruptness off throttle offroad. I put the stock cam sprocket back on, which helped a bunch. The carb liked the cam advance, apparently the EFI does not.
Power is up everywhere. The 1st measured tank, came in at 18.6 mpg. I took this with a grain of salt, because most of that was WOT tuning and idling in the garage.
2nd tank measured 22.7 mpg without even trying. I'm really pleased with that.
We sometimes jump in with some of the local offroad groups on their outings. One memorable outing to Death Valley had 30 or so participants with a geologist in the lead vehicle pointing out interesting rock formations over the radio.
So I needed to install a radio.
I have a taller indestructible stainless whip for offroad use.
chad
Post #126 by chad » Tue Dec 27, 2016 11:38 pm
CBs only available used now?
Still got mine, aint kept up w/the newer technology.
Lotta guys went to cellie but that's "isolating".
Where U @ probably lacka towers?
Glad 2 C U cont. with progress!
What do U have for tires now?
Post #127 by bubba22349 » Tue Dec 27, 2016 11:45 pm
:thumbup: That's some really great MPG numbers, as a comparison what did the old carb setup do? :nod:
MechRick
Post #128 by MechRick » Wed Dec 28, 2016 10:56 am
chad wrote:CBs only available used now?
You can still get them, but not like this one.
I had an unlocked 10 meter rig in my last Samurai, but it died from the constant vibration. Old school units without smc's are better for 4x4's.
bubba22349 wrote:what did the old carb setup do?
Best of 21, averaged 20. I think with a light foot and some more tuning I'll see 23-24.
chad
Post #129 by chad » Thu Dec 29, 2016 7:54 pm
"...the old carb…"
yeah?
MechRick
Post #130 by MechRick » Thu Dec 29, 2016 8:11 pm
chad wrote:"...the old carb…"
Yep. Old. Outdated. Antiquated. Obsolete. Useless. Did I step on any toes? :rolflmao:
I think I'm just going to inject everything from now on...
MechRick
Post #131 by MechRick » Fri Sep 01, 2017 12:16 am
It's been half a year since I've done any work to the Bronco. Jumped in it to move it a few weeks ago and it was a crank no start. Fuel pump failed (again).
I think it may have been a fluke, the fuel system is clean. Warrantied it out, and since this is a trail vehicle, I cut an access hole in the back.
chad
update - lima powered bronk
Post #132 by chad » Fri Sep 01, 2017 8:27 pm
nice...
my buddy just did that 2 es ford van, same prob - several replace in 2 shorta time.
He didn't use the goop tho.(just screws)
What kind did U use?
How's the rig run? wheel?
sounds like U kinda abandoned it?
I 4get - U use the pinto carb (H/W progressive)? I really like that carb but need
info on how it does on the inclines & gradients (fuel starve/slosh).
It would B placed on a 4.3 '69 mustang 250 in a '66 bronk (re-jet?).
MechRick
Post #133 by MechRick » Mon Sep 04, 2017 9:12 pm
The goop is body filler. It makes a level surface for silicone to seal.
It's very capable off road. I haven't had it on extreme trails yet.
My job has me bouncing around states, so I dropped the registration for now...
chad
1984 BII repower w/ 2.3L -H/W progressive carb-
Post #134 by chad » Tue Sep 05, 2017 12:11 am
Thanks!
It had been awhile so I reread some of your posts.
"...I 4get - U use the pinto carb (H/W progressive)? I really like that carb but need
info on how it does on the inclines & gradients (fuel starve/slosh)..."
I see you changed out the Weber 32/36 to a megasq.
Did the progressive do OK on the gradients or U never really got out there?
MechRick
Post #135 by MechRick » Tue Sep 05, 2017 8:24 am
Never got the chance to try it out on slopes. Webers are known for issues on slopes. This one got excess fuel on hard braking, so I imagine it would have problems on a down hill. The injection is worth 2 mpg and some torque.
chad
Post #136 by chad » Tue Sep 05, 2017 2:15 pm
K.
still a great way (what U got now) to go
for the B II, enjoy it when U can,
thanks for sharin.
Next project?
MechRick
Post #137 by MechRick » Sun Sep 02, 2018 10:37 am
Back in Nevada finally. Driving the Bronco again.
Got rear-ended in a rain storm (I could stop, guy behind me didn't). Bumpers and exhaust were damaged.
Hammered the rear bumper and swing out straight again, tossed the front bumper and did something in the plans anyway, mounted a high lift jack on the front.
MechRick
Post #138 by MechRick » Sun Sep 02, 2018 10:51 am
I tweaked the drive pullies. Using a crank hub and machining an Escort crank pulley to fit dropped the diameter a bit.
Installed a bigger alternator pulley.
The goal is to slow the clutch driven fan and A/C pulley to reduce drag on the engine.
MechRick
Post #139 by MechRick » Sun Sep 02, 2018 10:57 am
Fitted bigger tires. Had to trim the front sheet metal and body lift it, something I did not want to do, but tire rub off road forced my hand.
I used 2" square steel tubing cut into blocks and reinforced with round tubing. Body mount bolts are metric (12x1.75). I bought some 8" NC bolts and rethreaded them.
MechRick
Post #140 by MechRick » Sun Sep 02, 2018 10:59 am
MechRick
Post #141 by MechRick » Sun Sep 02, 2018 11:02 am
Body mounts are new. Getting the old body mount sleeves apart took the better part of a weekend.
Steering shaft had to be lengthened 1.5".
MechRick
Post #142 by MechRick » Sun Sep 02, 2018 11:07 am
The body lift had an expected benefit. The header for a car application I had hanging on the shop wall now clears the evaporator plenum. Installed it and welded up some 2.5" pipe.
Going to work on making it all the same color now.
chad
jackin'er
Post #143 by chad » Sun Sep 02, 2018 1:47 pm
4 - 6 inch BL?
What sz tire (all 3 'aspects') now?
Didn't even C a fender change in all this. U said trim...
MechRick
Post #144 by MechRick » Sun Sep 02, 2018 10:44 pm
Untrimmed...
...and trimmed.
See the difference? It's subtile, especially in the rear.
chad
clearencin the 4 fenders
Post #145 by chad » Mon Sep 03, 2018 1:20 am
did U roll the edge or sompin? Hard 4 me ta C any but the frnt of the frnt...
nice.
MechRick
Post #146 by MechRick » Tue Sep 04, 2018 3:23 pm
I intended to roll the edge, but it looks good enough I may not.
Body lift with the 2" square tubing is 2", tires are 31x10.50-15.
Also removed the carpet (had to to access the body mount bolts), and although I intend to replace the carpet at some point (I'm not fond of red interiors), decided to give it a scrub.
And, picked up a 5 speed (TK5). It will be a while before it gets installed, I'll need 4.56 or 4.88 gears to make it work. If I'm buying gears, I'd rather get them for an 8.8 and Dana 35. Driveshafts will need altering.
chad
lifted Bronco II
Post #147 by chad » Tue Sep 04, 2018 4:57 pm
what's the closest 8.8 inch 4 the swap? Will it need 2B shortened ?
"...Body lift with the 2"..."
WoW, the pic all ways throw me off. Looked like
4 inches.
MechRick
Post #148 by MechRick » Tue Sep 04, 2018 6:37 pm
Explorers have 31 spline axles, but need perches welded on top of the axle tubes. About 1.5" wider.
Later ones have disc brakes in the rear, desirable in the event the C clip 'hat' breaks off for axle retention.
Keeping my eyes open, may score one from a 4.10-equipped Explorer if I'm diligent...
chad
Bronco II - new axels/chunk
Post #149 by chad » Tue Sep 04, 2018 6:54 pm
So an Expl will B 3 inches too wide total? What a surprise (need 94 inches in the end).
Lazy JW
FSP Moderator
Post #150 by Lazy JW » Thu Sep 06, 2018 11:59 am
@ MechRick,
You do some truly amazing work, and your documentation is definitely first class. Thank you for taking the time and effort to share your project with us :thumbup: :nod:
Joe
"The White OX" 1974 F-350 300-6, Stock single exhaust, Carter YF, T-18A, Dana70 w/4.11, Flatbed dually w/dump bed. "Where no oxen are, the crib is clean, but much increase is by the strength of the ox" (Proverbs 14:4)
