Dany,
Sorry for the length but here it goes:
The engine is going to be .030" over, 1956 Hornet 308.
So far I have:
1) Clifford high-compression head & copper head gasket.
2) three intakes to try, four bbl alum. with 625cfm Carter, tri-power tunnel ram with three Stromberg WW 2bbls, and home made dual quad intake with twin 585cfm Carter AFB's.
3) Clifford 1-3/4" dual outlet headers. Planing on flowmaster 2-1/2" exhaust.
4) Custom ground cam from Randy Mass thats .406" lift 242 degree duration at .050" lift with 113.5 lobe seperation angle, new solid lifters & double roller timing chain & gear set modified from a Pontiac V-8.
5) Modifying a Pontiac Fluidampner harmonic balancer to fit the Hudson crankshaft & timing cover seal. (I havn't got this far yet so I am not sure what is needed.)
6) I am going to use ARP studs for mains, head and 351C rod bolts. Will use 1/2" ARP LugNuts for the head bolts, turned over with large diameter flat washers to increase head nut clamping area.
7) Planning on installing 2.00" intake and 1.625"(?) exhaust valves,
relieving & proting the block per directions & pictures Randy supplied me.
8) Will be modifying a Chrysler slant 6 electronic distributor to work in the Hudson block. Also planning on staying with the MSD 6AL ignition.
9) Other items I am also going to look at is O-Ringing the complete cylinder, valve relieve area & all water passages. Once again Randy showed me a lot of problems he ran into with head gasket sealing. The oval water ports above the center two main webs would blow between cylinders in some engines. This was something he was looking at doing and I believe it will be a good idea to do on mine as well.
10) Last engine related item was possible modification of big block Mopar oil pump to fit Hudson block to provide full-flow oil filtertration as well as increased pump output with same low power draw gear-rotor pump.
I plan on installing a GM (YUCK!, but dependable) 350 turbohydramatic
transmission with manual valve body and 2400 rpm converter. A 9-inch Ford rearend out of a 1966 Fairlane with 31 spline axels, loc-rite differential and 3.55 gears mounted to the stock Hudson leaf springs.
Car is a 1950 Hudson Pacemaker 2-door coupe. Presently taking up 1/2 of my garage and most of my basement. Hope to have it ready for next spring for some good, clean bracket racing. Looking to upgrade to more power with a "Boosted" power added it the head sealing problems don't show up with this set-up.
Its real hungry, must feed it Chevys or it will starve!
Any technical advice you can provide will be put to good use.
Thank you,
Ralph
