I'm about done with my engine rebuild and am ready to put the manifolds on but have a couple questions about the gaskets or lack of. My engine is a 1961 vintage (going into a 55 ford) it had steel rings and thin steel gaskets on the intake only none on the exhaust, the gasket kit came with a fiber/steel gasket but says no gaskets are used on 3 bolt manifolds. I think I have a 3 bold manifld (3 bolts holding the intake and exhaust together). So should I just re-use the steel rings? or the whole gasket? any sealer to be used? anything to whatch for? Any help would sure be appreciated. Thank you
Brad
Brad
