mrkling
I recently bought a 49 Shoebox Ford with a Flathead 6 (226). After years of sitting I recently was able to get it running (with help from the shoeboxford forum guys). I never got to road test it because it wasn’t legal (plates, ect). It idled and revved fine but it had a slight tapping noise. I’ve read on many threads how great Marvel Mystery Oil is for things like that. I poured some in the gas and engine oil as directed. I poured some down the carb while the engine was running, it smoked like everyone said it would. Then it started running rough and backfired through the carb. Now it starts and idles rough, if I give it any throttle it dies immediately. So far I’ve
Disconnected the fuel line to the carb and cranked the engine – its getting fuel
Tore apart the recently re-built carb (1bbl ford 8ha) to check for blockages and replaced the power jet assembly and fuel mixture needle
Replaced the points, condenser, cap, rotor, and plugs – firing order is good
Performed a compression test – all cylinders between 95-100
Re-set timing with vacume disconnected
Ran engine with vacume disconnected at distributor – no change
Checked for vacume leaks by spraying carb fluid around the based of the carb and vacume hoses – none found
Tailpipe is clear of obstructions
After all this I got another backfire.....I’m out of ideas please help!!!
