I am having issues with my '53 F-350 with 215 ci 6-cylinder. The engine stumbles greatly off of idle, you can hear it sucking in air through the carb . You have to feather the gas, or have the choke pulled out, or have the truck running at 1200 rpm for it to get the through the stumble. I've tried adjusting the timing and I've also adjusted the air/fuel mixture screw both in and out, but it still stumbles. I've also looked for vacuum leaks at intake and carb base, but couldn't find one Any ideas?? Thanks.
Rusty
Rusty
