Yes, fully recommended. Along with Front Disk Brakes with a Dual MC and the T5 make these old pickups into a very good daily driver able to handle modern driving. I did mine about 6 years ago and am very well pleased. Slowed the engine down considerably, less noise, and slightly better gas mileage makes it a lot more pleasant to drive for any distance too. I have run mine crosscountry and plan to do so again. In John's "kit" is an adapter plate w/mounting bolts, a clutch disk & PP, a pilot Brg, and a TO Brg on a special collar to fit the older clutch fork and the input snout of the T5. You will need a 1532-236 or 1532-238 T5 Trans and a shorter driveshaft. Your present output yoke should work in the T5. Did have to "adjust" the flat trans hump slightly as the T5 is a little taller than the old trans. Had to make a small plate to move the shifter lever about 3 inches forward to clear the seat in the 2nd, 4th, & Rev positions. More than happy to answer any more questions you may have.
Fred
