The only other engines the flywheel will fit is the 215 and 223 sixes. When I raced a 223 many years ago was breaking the clutch fingers pivots so swapped in a 262 truck clutch assembly. The clutch and disk may fit the Y block and FE V8's if they have the big truck flywheel I have a 317 (big Ford truck) engine that has that clutch on it.
