What do you all think? Love to hear your thoughts. I have big plans. I have to start with the carb cause it leaking pretty bad. Can only afford a rebuild kit at moment. Unless theres a cheaper options ( or not so expensive ). I also MUST get the gearing down. I found out from the tag on the diff that I have 3.89. Even with the taller gears she doesn't like 60mph at all. I want her to be a daily driver so i need to get down around 3.4. Can i just swap ring and pinion only? OR can I swap my entire rearend from a pars truck? what size rear end and how do i measure or find out? What other will fit? So many questions. THANKS!!!
