Anybody done this? I'd like to run a single exhaust as I have a complete LMC exhaust system still in the box. Any clearance issues to deal with? Truck is a '59 F100
Have not used the patriot header but the Cliffords fit nice. I think you should be OK as long as you make sure the mounting washers fit well ie the heights match for intake and header bolts or studs, grind or make the washers so they fit nice. Only other fitting should be the collector reducer to exhaust pipe minor cut fit and weld the rest should bolt on as stock. Good luck
