They orginally used a rope seal, you will need to remove the oil pan and the rear main cap and then loosen up all the other mains enough to install a new one. There was a tool called a Sneaky Pete to help remove and install a new rope seal. I don't know if there is a newer lip type seal that will fit but maybe they do make one for the 215 Ford engines. Good luck
