Not sure If this answers your question but the .500 needs the guides to be machined in order for them to fit; however, this will create a better seal. The .530 should slide over stock. This is however for the the 144/170/200/250 family. I'm not sure if the 223 is any different, but I do think you can still machine your guides to fit the .500 seals if you wanted.
