oil filter 226 motor
blionl
I need the fiber / rubber washer that is under the bolt that holds the top cover down on the filter of my 1950 226 engine . Thanks Brian
You should be able to get those at NAPA or other good Auto parts houses. :nod:
from www.rockauto.com:
FRAM Part # C4 {Click Info Link for Alternate/OEM Part Numbers} Cartridge full flow
w/standard mediaPart Image $6.17
WIX Part # 51006 {Click Info Link for Alternate/OEM Part Numbers} Part Image $9.91
FRAM Part # C4P {Click Info Link for Alternate/OEM Part Numbers} Cartridge full flow; Includes Gasket
"P" version is stacked disc media; w/AC-Delco SC-353 filter; For pleated paper media drop "P" suffix Part Image $11.50
