58custom223
This forum has been a big help and there is so much I've learned in a short time that I'm almost suffering from "analysis paralysis". Maybe someone has been down the road I am heading and can whittle down my options a little while figuring what modifications/upgrades to make to the 223 in my Custom 300.
What I'm trying to accomplish:
1 - The car will be used to pull a small travel trailer. 2600# maximum, worst case. More than likely it will be more around the 2400# mark. The Lo-Liner has a lower profile and does not catch as much wind as would typically found in similar travel trailers.
2 - Before traveling next summer, a AC unit of some kind will be installed. Have not settled on a make yet, but will take any suggestions that can be offered from folks who've gone this route.
Here's what I've done or plan to do:
1 - Done - Radiator has been rebuilt with a core containing 25% more coolant passages. This was done to take into account the trailer and AC loads.
2 - In Process - Replace engine driven fan with an electric. Don't need that added load at highway speeds.
3 - In Process - Electric Water Pump. Will deliver a constant flow of coolant regardless of engine speed and reduce the load from the water pump. Low current draw (6-8 amps) will have less added effect on the generator than the water pump load.
I'd like a bit more HP but not in the upper RPMs. Ideally, it would be in the 2000-3500 RPM range where the car will be driven on the highways, byways, and hills. I've seen mention of a number of options that may be of help in this area so thought I'd toss out some ideas to see what has been found to work best.
Improved breathing for both intake and exhaust:
(A) Blueprinting the head for better flow but not TOO much flow to negatively impact lower speed efficiency.
(B) Larger Valves with 4 angle cut.
(C) An RV grind on the cam.
(D) Without needing more power in the upper RPM range, it sounds like the Holley 1904 and stock manifold should do the trick without mods.
(E) The stock exhaust manifold with a good 3-chamber muffler (2.5" pipes) should also do the trick.
What do "the experts" think? Am I on the right trail or barking up the wrong tree? (I love speaking in metaphor.)
