Daves55Courier
I am considering replacing the load-o-matic distributor in a '55 Ford Courier sedan delivery with a 72 Ford 240cid distributor which has mechanical advance, but first I have a couple questions for those who have done it and have produced a successful outcome in engine performance at all speeds.
1) How is the vacuum run to the dizzy vacuum advance can in the '72 Ford truck? did they run it off the intake manifold plug?
2) How can I be sure that the factory advance curve of the 240cid engine will work with the 223 engine without additional modifications? The 240 dizzy does not have advance curve adjustments above the breaker plate. Input please!
3) I've heard of some people welding the 1/4 dizzy drive shaft to the 1/4" to 5/16 adaptor (required to drive dizzy from existing 1/4" drive with older oil pump in the pre-1964 engine. I am not going to do that. If the shaft and adaptor are not perfectly straight I fear premature wear of the dizzy shaft bushing. Also it would be difficult to achieve symmetrical balance. what have other people done to furnish a balanced shaft assembly (short of dropping the pan and replacing oil pump with one from a 1964 223 engine) ?
