2018 Contributors:
Stacked carb gaskets?
Berths
New Member
Post #1 by Berths » Mon Oct 23, 2017 12:15 am
Hi,
I just had the carb on my 53 custom line with the straight six rebuilt.
I went to remove the old gasket to reinstall it and found that there was no less than 6 gaskets stacked together.
Is there a reason that this was done?
Would it have been done to isolate the carb more from the hot manifold?
They were not glued together, they did have a staple through them on each side.
This was my great grandmother's car and all the guys that I know would have worked on it have passed on.
Thanks in advance for any knowledge of why this may have been done
Re: Stacked carb gaskets?
Post #2 by bubba22349 » Mon Oct 23, 2017 10:14 pm
Berths wrote:Hi,
Yes you are correct the multiple gaskets are used to isolate the carb from the heat of the intake / exhaust manifolds. The staples used is how many of these thick carb base gaskets were made for the mid 1970's up emissions equipped engines. Good luck :nod:
cars2cool
Post #3 by cars2cool » Tue Oct 24, 2017 11:34 pm
The thickness will change the idle speed. A shorter height will cause a fast idle I could not adjust for. So i re-installed my original gasket/spacer stack and it straightened out. It had to do with the linkage travel.
I'm a Fordaholic! '30 Model A pickup, '55 & '56 F100, '76 Lincoln Town Car w/64k miles "cream puff"
