power
flyinturtle84
New Member
power
Post #1 by flyinturtle84 » Tue Oct 10, 2017 7:50 pm
Hi I have an 84 Ford f150 with a 300i 6 in it. I was wondering how I could get a good amoumt of horsepower out of it
THE FRENCHTOWN FLYER
Re: power
Post #2 by THE FRENCHTOWN FLYER » Tue Oct 10, 2017 10:17 pm
low restriction exhaust
better intake
stouter cam
more compression
head work
Harte3
Re: power
Post #3 by Harte3 » Wed Oct 11, 2017 11:48 am
Start reading this Forum, take notes, make a plan, work the plan.
'83 F150 300, 0.030 over, Offy DP, Holley 4160/1848-1 465 cfm, Comp Cam 260H. P/P head, EFI exhaust manifolds, Walker Y Pipe, Super Cat, Turbo muffler, Recurved DSII, Mallory HyFire 6a, ACCEL Super Stock Coil, Taylor 8mm Wires, EFI plugs.
1986F150six
Re: power
Post #4 by 1986F150six » Thu Oct 12, 2017 10:49 am
THE FRENCHTOWN FLYER wrote:low restriction exhaust
better intake
stouter cam
more compression
head work
If simply going for the best gas mileage with a stock engine, can a "low restriction exhaust" be accomplished without replacing the stock exhaust manifold?
Re: power
Post #5 by THE FRENCHTOWN FLYER » Thu Oct 12, 2017 6:07 pm
better intake
stouter cam
more compression
head work
Yes, it will help, but a higher flowing exhaust manifold, e.g. EFI manifolds, will certainly yield a greater benefit.
flyinturtle84
New Member
Re: power
Post #6 by flyinturtle84 » Thu Oct 12, 2017 8:50 pm
[quote="THE FRENCHTOWN FLYER"]low restriction exhaust
better intake
stouter cam
more compression
head work[/quote
This maybe a dumb question but how do you get higher compression ratio. I'm new to the engine building scene
wallen7
Re: power
Post #7 by wallen7 » Thu Oct 12, 2017 10:00 pm
Mill the head. If you are doing a complete rebuild , mill the top of the block. The piston is general about .040 down and milling the block will up the compression. Different pistons can up compressionalso.
Dr Jay
Re: power
Post #8 by Dr Jay » Sun Oct 15, 2017 8:57 am
Install a 240 head! The Ford 300 in-line six head can be replaced with the head off of a 240 cubic inch inline six. Smaller combustion chamber gives a higher compression ratio!
Blessings,
Dr Jay
1978 F100 Shortie, Lowered front and rear, 300 .030 over, 240 head, Clifford, Holley 390
252 Comp Cam, Cloyes, Fuel Inj. exhaust manifolds, MSD 6A, TOD, 9"
Users browsing this forum: No registered users and 11 guests
