Edelbrock/Carter AFB throttle linkage
jgetti
Post #1 by jgetti » Mon Oct 17, 2005 5:38 pm
All,
I've finally gotten my engine dropped in the truck and am now eyeballing how I want to do the throttle linkage. The truck has a C6 cranny, and I've already purchased the kick down cable from Lokar. As far as the throttle goes, the truck is a 1980 and has the cruise contol bellows/canister that still works (or did before this rebuild). I'd like to see what others have done as far as the throttle cable choice, direction of carb mount, pictures if possible. I would especially like to see pictures with the edelbrock/Carter AFB style carbs if possible.
Thanks!
80broncoman
Post #2 by 80broncoman » Mon Oct 17, 2005 6:36 pm
I have pics of mine, but my carb is sideways like it is on a Dual Port intake.
I had to have a new cable cause my stock one was too short. I bought a cable for a 90 F-150 302 truck, and I bought a universal cable bracket both from AutoZoo.
OAPSE Union Member
Real men don't wear Bowties
jgetti
Post #3 by jgetti » Tue Oct 18, 2005 12:36 pm
80broncoman wrote:I have pics of mine, but my carb is sideways like it is on a Dual Port intake.
I'd appreciate pics if you can provide them. Thanks for the info!
80broncoman
Post #4 by 80broncoman » Wed Oct 19, 2005 12:38 am
Sorry,
I goofed I ment to say I didn't have pics. :oops:
OAPSE Union Member
John89
New Member
Re: Edelbrock/Carter AFB throttle linkage
Post #5 by John89 » Wed Oct 09, 2019 12:49 am
My son and I are installing an Edelbrock 1403 on an Offy dp intake. We need suggestions for the throttle cable routing etc...
80Broncoman if you are still active maybe some pics of yours.
Our throttle stud pulls to the passenger side. Stock cable pulls to drivers side.
We are thinking of trying to run about 60" of cable around the front of the carb (front of truck). I haven't been able to find any cables long enough with the proper ends.
78 F150, 4WD, 4spd, PS.
John89
New Member
Post #6 by John89 » Wed Oct 09, 2019 12:51 am
78 F150 4WD 4spd.
MechRick
Post #7 by MechRick » Wed Oct 09, 2019 4:14 pm
I've run into this on Jeeps. My solution was to run a spacer (in your case it would have to be a 4 hole), extend the throttle arm down and cable pull from the bottom instead of the top.
Stock cam, aluminum cam gear
THE FRENCHTOWN FLYER
Post #8 by THE FRENCHTOWN FLYER » Wed Oct 09, 2019 8:18 pm
Make a bell crank. You can change travel ratios if necessary for optimum.
