weighed my 300 engine today..
ivonius
Post #1 by ivonius » Sun Mar 22, 2009 10:21 pm
...for the long block: with flywheel, valve cover and oil pan in place, but with NO crank dampener, no manifolds, no starter, no generator, no ps pump, etc.: 420 lbs!!! This was a real surprise seeing as my boat-anchor of a 4-cylinder (2.2 liter) that I am replacing in my Triumph TR4 weighs 400 lbs dressed the same way. So going from 2.2 L to 4.9 L is only costing 20 lbs. And if I put in a lightweight flywheel (say, 20 lb vs the stock 30), a lighter starter (say 14 lbs vs TR 19) and tube headers vs TR 13 lb cast, we get to almost break even. --Good times ahead.
PS. It's a 1993 EFI I bought from a salvage yard this week. Pulled off a bazillion lbs. of stuff to get to the essential engine. Now where is a good T5 Mustang 5.0L trans?
..bunch of Audis, + building a 67 Triumph Tr4a with 4.9 Ford. Gone but not forgotten: 66 Jaguar XKE (4.2 L6), several Triumphs (TR6 2.5 L6) , a couple of MG's, Datsun 280Z (2.8 L6), 64 Valiant Wagon (225 slant-six), three 57 Chevy's, 62 Impala, two Corvairs, etc; Worked high school & college at a Ford dealer as a mechanic (1968-1974). -Do all my own work
American Thunder
Post #2 by American Thunder » Sun Mar 22, 2009 11:23 pm
A whole mustang t5 donor car would be nice, to get all the pieces.
Are you swapping the stock rear for an 8.8?
1977 530hp 302 Mustang II videos:
Smokeshow at 8000 rpm
0-90 mph speedometer view
1983 4x4 Bronco - '95 300 converted to carb, 5-speed, 3.55 gears and 9" rear.
ivonius
Post #3 by ivonius » Mon Mar 23, 2009 12:01 am
--already installed an Infiniti Q45 limited-slip rear (the Triumph is independant rear suspension).... 3.68 gears.
mutt
Post #4 by mutt » Mon Mar 23, 2009 11:54 am
now thats interesting....I knew those Brit 4's were massive lumps, but that they are only a tad lighter than a big six is astounding.
What does (for instance) a 289 similarly attired wiegh??
AbandonedBronco
Post #5 by AbandonedBronco » Mon Mar 23, 2009 11:56 am
That's really interesting to know! I know there's been a lot of debate over the years as to the actual weight of the engine.
1985 Ford Bronco Eddie Bauer. 300 I6. 9.1:1 CR, roller rockers, EFI manifolds and 2.5" exhaust. DUI ignition. 3.55 final drive, 5 speed ZF5. Holley Sniper EFI w/Offenhauser C Intake. 32" BFG KO2 A/Ts.
American Thunder
Post #6 by American Thunder » Mon Mar 23, 2009 9:44 pm
mutt wrote:now thats interesting....I knew those Brit 4's were massive lumps, but that they are only a tad lighter than a big six is astounding.
As far as I know, a 289/302 complete, weighs about 550 lbs.
J.R.
Post #7 by J.R. » Wed Mar 25, 2009 5:14 am
American Thunder wrote: "As far as I know, a 289/302 complete, weighs about 550 lbs."
Engine weight chart: http://www.35pickup.com/mulligan/weight.txt
Weights are always a bit edgy to quote, but I think the 289/302 is closer to 450-470lbs. The 351W with factory iron manifolds is around 550-560. Now a nice 302/347" SBF with aluminum heads & intake, lightweight starter, and short headers would be in the same weight range as the 2.2L Triumph or the 300" six, maybe even lighter, and definitely shorter than the BB6.
J.R.
SoCal
66 E100 Pickup
Post #8 by 66 E100 Pickup » Thu Mar 26, 2009 12:22 am
I had two guys from the engine shop lift my empty 240 block from ground level and set it in my Subaru. I couldn't believe it!
Guessing the block alone is less than 300 lbs. Head is big time heavy, about 50 lbs, and crank is a good 30 lbs or more.
Hmmm a nice alum alloy head...wherefore art thou...
John
Lazy JW
FSP Moderator
Post #9 by Lazy JW » Thu Mar 26, 2009 8:46 am
66 E100 Pickup wrote:I had two guys from the engine shop lift my empty 240 block from ground level and set it in my Subaru. I couldn't believe it!
Guessing the block alone is less than 300 lbs.....
Mmmmmmmm......... it's a good deal LESS than that. I have lifted bare 300 blocks several times into a pickup bed by myself and didn't consider it to be any heroic feat. Take the crank, cam and piston/rod assemblies out and there really isn't much left on a thin-wall casting. Wouldn't want to try it with a 262 block though :shock: Or my International 240 Silver Diamond Six :lol:
Joe
"The White OX" 1974 F-350 300-6, Stock single exhaust, Carter YF, T-18A, Dana70 w/4.11, Flatbed dually w/dump bed. "Where no oxen are, the crib is clean, but much increase is by the strength of the ox" (Proverbs 14:4)
American Thunder
Post #10 by American Thunder » Thu Mar 26, 2009 8:54 pm
Back when I was younger,(and my back was still in one piece) I walked into the machinist shop carrying a bare 302 block in each hand by the main cap. raaah!
ivonius
Post #11 by ivonius » Fri Mar 27, 2009 8:05 pm
Shoot that ain't nothin. I wunst lifted up a Bluebird bus filled with midgets, so they could change a tire
American Thunder
Post #12 by American Thunder » Sat Mar 28, 2009 9:32 am
Did they have their pet ferrets onboard??
crash-harris
Post #13 by crash-harris » Sun Mar 29, 2009 2:35 pm
My dad seemed concerned when Dakota put the 300 EFI block in the back of the truck. I've been dragging that thing out whenever I get the chance to just to observe it. The log head has to weigh nearly as much as the bare block.
Bruiser - 1990 Ford F150...barely...EFI 300 Big Six, 500K+!, converted to 4x4. 4.10 gears and Sterling FF rear w/ Trac-Lok, 37" meats. Undergoing 1 Ton leaf spring SAS. 6BT in the plans.
Stonebreaker
Re:
Post #14 by Stonebreaker » Fri Mar 02, 2018 8:52 am
J.R. wrote:American Thunder wrote: "As far as I know, a 289/302 complete, weighs about 550 lbs."
J.R.
SoCal
Ford Performance quotes a Boss 302 iron block with aluminum heads, no flywheel, no intake and exhaust manifolds as 560 lbs. which is right in line with a smallblock chevy at 550 lbs in the same configuration. It's not till you get to the aluminum block coyote motors that you get below 500, and they're still 470.
I am glad to see the 420 lb confirmed weight for the longblock 300. Now if they can get that 300 aluminum head project into production I'll be a happy camper.
bmbm40
Re: weighed my 300 engine today..
Post #15 by bmbm40 » Fri Mar 02, 2018 7:47 pm
That is good info to know. How did you weigh it? Thanks
NEXT- direct mount 2v, power brakes, rear LS, 3G, electric fan, electric upgrades, custom curved DSII, header, 31" tires
chad
Post #16 by chad » Thu Mar 08, 2018 1:08 am
seen that chart B4. Many say it conflicts w/reality and quote different numbers. I, on the other hand have no proof but do watch these things as they go by...
Users browsing this forum: No registered users and 15 guests
