shoulda used a Ford 300...dang
66 E100 Pickup
Post #1 by 66 E100 Pickup » Wed Jun 03, 2009 11:01 am
This is a quick way to check out your pistons :lol: :shock: .
http://d.yimg.com/kq/groups/1132697/429873568/name/TRACTOR%20BANG.wmv
John
ludwig
Re: shoulda used a Ford 300...dang
Post #2 by ludwig » Wed Jun 03, 2009 4:00 pm
Woah!!! :shock: Check out where the payload landed.
lakesidepark
Post #3 by lakesidepark » Wed Jun 03, 2009 5:01 pm
But if its .001 too tight EVERYBODY KNOWS!!
Is this video kinda what 80Broncoman was referring to in his sig? It does look like something was under a bit of tension...
the fleet @lakesidepark:
1986 F150 300 C6 (the blue rusty beast)
2001 Ranger 3.0 auto (bug truck)
1997 Cadillac Catera (misery for another forum)
1987 Ranger 2.9 5spd (over 300K, sold it but it still leaves home every day)
1980 TR7 w /4.1L Buick GN V6 / 200R4 (ongoing project)
AbandonedBronco
Post #4 by AbandonedBronco » Thu Jun 04, 2009 10:28 am
Should just need a new headgasket.
Wow, that thing is toast.
1985 Ford Bronco Eddie Bauer. 300 I6. 9.1:1 CR, roller rockers, EFI manifolds and 2.5" exhaust. DUI ignition. 3.55 final drive, 5 speed ZF5. Holley Sniper EFI w/Offenhauser C Intake. 32" BFG KO2 A/Ts.
wheels_adam
Post #5 by wheels_adam » Sun Jun 07, 2009 9:49 am
When your making upwards of 2500+ hp and crazy amounts of boost, somethings under tension.
American Thunder
Post #6 by American Thunder » Sun Jun 07, 2009 6:47 pm
Ouch.
Bruce Crower told me once that the pulling diesels are making 10,000+ ft/lbs of torque and run 100+ psi of boost. He also said that to keep the pistons from immediately vaporizing under such heat, they plumb big nozzles under each one, which spray motor oil at them.
1977 530hp 302 Mustang II videos:
Smokeshow at 8000 rpm
0-90 mph speedometer view
1983 4x4 Bronco - '95 300 converted to carb, 5-speed, 3.55 gears and 9" rear.
wheels_adam
Post #7 by wheels_adam » Tue Jun 09, 2009 7:43 pm
I would never go against the word of Bruce Crower(and i feel bad for even saying this) but i doubt 10,000 ft lbs out of a 500-600 cube diesel. Ive seen what goes inside of the alky burning 4 turbo tractors, and they are similar, but in my mind that much stress would need bigger components then whats already put into them. As you can see the blocks are the weak point when that much power is made anyway
crash-harris
Post #8 by crash-harris » Thu Jun 11, 2009 5:04 pm
Dang! Blew the block right off the pistons and rods! :twisted:
If it breaks, it just means you didn't build it well enough :nod:
Bruiser - 1990 Ford F150...barely...EFI 300 Big Six, 500K+!, converted to 4x4. 4.10 gears and Sterling FF rear w/ Trac-Lok, 37" meats. Undergoing 1 Ton leaf spring SAS. 6BT in the plans.
American Thunder
Post #9 by American Thunder » Thu Jun 18, 2009 6:51 am
wheels_adam wrote:I would never go against the word of Bruce Crower(and i feel bad for even saying this) but i doubt 10,000 ft lbs out of a 500-600 cube diesel. Ive seen what goes inside of the alky burning 4 turbo tractors, and they are similar, but in my mind that much stress would need bigger components then whats already put into them. As you can see the blocks are the weak point when that much power is made anyway
I don't know, it's all way above my head in terms of personal engine building experience. Pulling motors are up there with top fuel/funny cars in the stratosphere of power sports. I sent Crower an email stating some of my opinions on his (new at the time) 6-stroke diesel water-injection design, and I left my phone number. Sure as heck, he called me up 2 days later at my house! I took a picture of the caller id on my phone.. Anyway, the guy is very intelligent and his level of knowledge is unreal. I'm sticking by what he said! 10,000 ft/lbs :D
Thad
FSP Moderator
Post #10 by Thad » Thu Jun 18, 2009 8:28 am
"If it breaks, it just means you didn't build it well enough" so sayeth Crash.
Not necessarily, in this case appears builder was able to build more power than the available engine block can handle.
Maybe next built he can find a stronger block, or turn the wick down just a little, doubt it, after, all the idea is win. :roll:
There are those who just dream,
and there are those who do more than dream. ><> = +
StrangeRanger
Post #11 by StrangeRanger » Thu Jun 18, 2009 10:42 am
Bruce Crower is no armchair expert. He knows whereof he speaks and can translate it into hardware. I met him at Bonneville a few years back; he was working with a Flathead Ford powered streamliner trying to break 300 MPH. They did.
1996 F-150 (tow missile)
1993 Mustang 5.0 (hot rod and auto-x monster)
1982 Tiga Formula Ford (SCCA racecar)
2013 Hyundai Elantra Coupe (daily driver)
CNC-Dude
Post #12 by CNC-Dude » Fri Jun 19, 2009 12:59 am
StrangeRanger wrote:Bruce Crower is no armchair expert. He knows whereof he speaks and can translate it into hardware. I met him at Bonneville a few years back; he was working with a Flathead Ford powered streamliner trying to break 300 MPH. They did.
Was that Ron Main's Flatfire 'liner?
StrangeRanger
Post #13 by StrangeRanger » Fri Jun 19, 2009 6:17 am
Yes.
CNC-Dude
Post #14 by CNC-Dude » Fri Jun 19, 2009 11:46 am
I like 21st century technology applied to vintage engines in that way. They claimed on their website that the engine cranked out over 700HP ....that is very awesome!
StrangeRanger
Post #15 by StrangeRanger » Fri Jun 19, 2009 12:09 pm
If you think about it, a flathead and a turbo are extremely compatible technologies.
Flatheads have low compression ratios and lots of room to open the ports up for monster flows plus the advantage of very low valvetrain inertias. Turbos require low compression ratios and monster flows and can push the engine to RPM levels where low valvetrain inertia becomes a real advantage. The real question is how they ever built the bottom end of a flattie to withstand that kind of BMEP and make that kind of power. Between Bruce Crower and the late Dick Landy, there was some major gearhead genius involved in that build.
CNC-Dude
Post #16 by CNC-Dude » Fri Jun 19, 2009 12:41 pm
I believe they used billet 4 bolt main caps and a custom main girdle for the lower end. That is impressive how a 3 main engine could endure that much stress. I forgot how much boost they said the engine made, I'll have to go back to their website to refresh my memory, it shows the engine in various stages of assembly, and there is a lot of trick pieces in it for sure.
StrangeRanger
Post #17 by StrangeRanger » Fri Jun 19, 2009 4:33 pm
No matter how well supported the mains are, there's still only 3 of them. The crank must be forged out of Unobtainium. Back "in the day" Landy used to make insane amounts of HP in his Pro-Stock Hemi but getting this thing to hang together for 8 miles at a time at Bonneville under that much boost is to my mind way more impressive
American Thunder
Post #18 by American Thunder » Fri Jun 19, 2009 9:36 pm
Going with the topic, Crower also told me about how he had stayed up late into the night building an engine for his daughter's S2000 race car. He used a set of his titanium rods, but in his late night haste, installed a floating pin a little too tight. It seized up at about 8000 rpm, blew the piston into fragments, and the titanium rod whirled around and cut the block in half. He said he was able to re-use the rod. Apparently, Crower titanium rods are durable?
StrangeRanger
Post #19 by StrangeRanger » Fri Jun 19, 2009 9:47 pm
That they must be. They're also as illegal as all heck in an S2000 engine :lol:
wallaka
Post #20 by wallaka » Mon Jun 22, 2009 9:30 pm
8000 RPM? Dang, didn't even get to the stock redline!
Down to 29 cylinders!
2006 Porsche Cayman H6, 1968 Mercury Monterey big block (390), 1967 F-100 240, 1965 Mercury Comet 404 (200), 2009 Triumph Street Triple
Users browsing this forum: Big64my79Effie and 75 guests
