2018 Contributors:
Oil filter stud
Turbo_B
Oil filter stud
Post #1 by Turbo_B » Tue Apr 10, 2012 5:53 am
Does the oil filter stud screw or press into the block?
1969 MGB - Bored, cam'd, aluminum head, MSEFI, turbo charged and intercooled at 10.5psi
1989 F150 - Stockish rebuild, Comp Cam, Megasquirt, turbo charged and intercooled at 14psi
Thad
FSP Moderator
Re: Oil filter stud
Post #2 by Thad » Tue Apr 10, 2012 10:24 am
Screws into block. Are you needing to remove?
There are those who just dream,
and there are those who do more than dream. ><> = +
Turbo_B
Re: Oil filter stud
Post #3 by Turbo_B » Tue Apr 10, 2012 8:50 pm
I am adding a sandwich adapter for an oil cooler, but the adapter puts the filter into the brake distribution block. So I am looking to fit a 90 degree filter adapter to the block and then the sandwich for the oil cooler between the 90 degree and the filter.
Long story short, I want to remove the stock oil filter stud.
Figured I should ask before I start!
Thanks for the help!
StrangeRanger
Re: Oil filter stud
Post #4 by StrangeRanger » Tue Apr 10, 2012 9:02 pm
The 90° adaptor should screw onto the stock stud.
1996 F-150 (tow missile)
1993 Mustang 5.0 (hot rod and auto-x monster)
1982 Tiga Formula Ford (SCCA racecar)
2013 Hyundai Elantra Coupe (daily driver)
Turbo_B
Re: Oil filter stud
Post #5 by Turbo_B » Tue Apr 10, 2012 9:16 pm
In my perpetual quest to be cheap, I found a 5.0L that uses a FL1A on a 90 degree adapter. But that stock 5.0L adapter screws into the block and not the stud.
woodbutcher
Re: Oil filter stud
Post #6 by woodbutcher » Wed Apr 11, 2012 1:47 am
:) Hi TurboB.What you might try,is to use two nuts on the stud.Tighten them together, and then screw the stud out by putting your wrench on the REAR nut.
Good luck.Have fun.Be safe.
Leo
Otto von Bismarck
Turbo_B
Re: Oil filter stud
Post #7 by Turbo_B » Wed Apr 11, 2012 5:36 am
Thanks for the advice. I read somewhere that the filter stud was pressed in, didn't want to remove something that I needed a press to reinstall!
BikeGramps
Re: Oil filter stud
Post #8 by BikeGramps » Wed Apr 11, 2012 8:14 pm
The filter " stud" should be a 1/2" pipe nipple. I have not pulled the one on the engine but that is what is in my remote filter mount. I would try an easy out tool of the correct size as nuts that fit a 3/4-13 npt thread may be difficult to find.Also if you need a longer one a 1/2" pipe nipple of the correct length should work. A plumbing shop should be able to make one at any length you require. Pipe threads are a taper thread so they will seal. I could be wrong, so be careful, maybe purchase a 1/2" pipe fitting to thread on and check.
bikegramps
This post is not correct. The thread is 3/4 - 16 national fine. sorry
FalconSedanDelivery
Re: Oil filter stud
Post #9 by FalconSedanDelivery » Wed Apr 11, 2012 8:22 pm
The Nipple is NOT Pipe Thread , it is threaded in , NOT pressed , Old style had a hex on it that you could use a socket and impact on , new has an internal 7/16 Allen to tighten and remove , many of the newer OEM have no provision for grabbing a hold , but if you do destroy it , most Ford dealers stock the replacement and its around 8 bucks
Falcon 6's, FE's I Like them both , Sold all My 6 cyl stuff ( for now at least ) glad to pass along some tips though
BikeGramps
Re: Oil filter stud
Post #10 by BikeGramps » Thu Apr 12, 2012 8:46 pm
I went out and looked at my 2 1975 blocks. It is not pipe thread, it is 3/4 - 16 bolt thread ( 3/4 NF ). There is no provision for removing either one- no nut or allen flats. So you could use 2 3/4 nf jam nuts or an easy out on mine. A jam nut is a 1/2 tall nut, there is not enough threads for 2 full size nuts. Sorry for the misinformation earlier.
bikegramps
StrangeRanger
Re: Oil filter stud
Post #11 by StrangeRanger » Thu Apr 12, 2012 9:53 pm
If you don't care about the condition it's in after you remove it, a pair of Vise-Grips makes a dandy removal tool :lol:
sdiesel
Re: Oil filter stud
Post #12 by sdiesel » Tue Apr 17, 2012 1:59 am
i use vise -grip pliers and junk the whole maryann and then get the ford adapter from a 460, that has the cooler ,lines, fittings, and adapter all at once. its a very nice setup and i can swing the filter into any angle i like, especially a lowered angle to keep the filter full after shut-of.
Does10s
FSP Moderator
Re: Oil filter stud
Post #13 by Does10s » Tue Apr 17, 2012 9:50 am
StrangeRanger wrote:If you don't care about the condition it's in after you remove it, a pair of Vise-Grips makes a dandy removal tool :lol:
Or cut a slot across the stud. Then insert a thin piece of metal and spin it out. A little thread clean up and it's usable again.
Later,
Will
'86 Mustang, Turbocharged, Best ET: 10.70@132.
'69 Mustang Sportsroof, 351w, auto
'63 Falcon, Turbocharged 250, C4, 9", Best ET: 10.64@127mph 11/21/14
Users browsing this forum: No registered users and 11 guests
