Need a carb for a 76 F100
Vin Man
Post #1 by Vin Man » Mon Nov 12, 2012 11:36 pm
Where is the best place to find a replacement carb for my 76 F100 with the inline? It is a 1bbl
-Vinny
67 Mustang Hardtop, 200 Inline 6 bored .040, OZ250 Head, Autolite 2100, DUI ignition setup and headers, front disc brakes, 8" rear end
My Engine History Thread: viewtopic.php?t=50725
CoupeBoy
Re: Need a carb for a 76 F100
Post #2 by CoupeBoy » Tue Nov 13, 2012 5:52 am
Fordsix forum, post a wanted ad. What type of carb are you looking for?
79granada
Post #3 by 79granada » Tue Nov 13, 2012 8:06 am
summit sels a carter yf remanufactured by holley fairly cheap for a carb. if i recall its less than 200 with no core i have one that possibly needs rebuilt that im willing to part with once i finish my 2bbl swap (hopefully this week) it came off my 250 granada i think they are about the same but it might be something to research. i believe autozone or advance and possibly orielys carries them too but not sure on the price
'79 granada 250 inline six 80,000 miles (gone)
'96 ranger 2.3 4cyl 5 speed
'96 chevy blazer 4x4 4.3 v6(wifes car, im trying to talk her into a ford)
'86 F-150 300 inline six automatic rust free 97000 miles
Vin Man
Post #4 by Vin Man » Tue Nov 13, 2012 9:54 am
I'm looking for the stock 1 bbl that was on the truck. Looks like Autozone or O'Reilly carry them in the $200 range as well. I was wondering if there was an alternative carb that people here used that they found gave superior performance or reliability at a better cost.
-Vinny
1986F150six
Post #5 by 1986F150six » Tue Nov 13, 2012 9:58 am
You might want to check with Rock Auto. A while back, I was able to get a Carter YF [1970 F350 - no emmissions] for $109 without a core charge. It was remanufactured by Autoline of Canada and has performed very well.
Vin Man
Post #6 by Vin Man » Tue Nov 13, 2012 2:50 pm
1986F150six wrote:You might want to check with Rock Auto. A while back, I was able to get a Carter YF [1970 F350 - no emmissions] for $109 without a core charge. It was remanufactured by Autoline of Canada and has performed very well.
Good suggestion. Best price yet - $135+$60 core. I have a core so no problem there.
-Vinny
79granada
Post #7 by 79granada » Tue Nov 13, 2012 9:15 pm
im trying to swap in a 2150 autolite 2bbl havent got it finished yet but ill let you know how it runs should have it running when i get off work in the morning
Ranger_gone_straight
Post #8 by Ranger_gone_straight » Sun Nov 25, 2012 10:57 am
They are getting rarer and more expensive, but ebay may still be best place. I pick cores up when I see them cheap as I know they will only become more $$$ and rarer. That probably do me rest of my life if I am honest with myself. As long as I can get rebuild kits. The ones from the chain stores tend to been cleaned and kit thrown in by minimum wage people or third world people that may never have seen a carb before. No check made on shaft wear and no flow bench testing. So you can pay a lot for a "clean repainted core" that you still have to rebuild. Or you may get lucky. Ask yourself when you hand over your $200, "do I feel lucky today????"
Holley 2bbl and Weber 38/38 still made and sold brand new. Not cheap and they have to be "dialed in" with proper jets, etc to work on a 300. But for those of us sticking with carb vehicles as long as possible, those might eventually be only realistic choices.
79granada
Post #9 by 79granada » Sun Nov 25, 2012 11:32 am
i got the 2150 on my 86 it runs better than it did before and i have less than 100 bucks in the swap 40 for the carb(used) 40 for the adapter(got it from summit it did require some very minor cutting with a die grinder) and 10 bucks at the junkyard for cables and brackets plus if i decide to upgrade the intake i have the carb. for anyone looking to get rid of the carter I'd suggest the 2100/2150 or a 350 holley two barrel
Vin Man
Post #10 by Vin Man » Sun Nov 25, 2012 5:47 pm
I went with the direct replacement from Rock Auto. Bolted right in and works fine. Thanks all!
-Vinny
Users browsing this forum: No registered users and 21 guests
