Can't remember
Broncitis
Can't remember
Post #1 by Broncitis » Mon May 13, 2013 12:07 am
Do any head bolts go into the water jacket on 300, thanks.
69 Early bronco, 4.11, toploader 4speed, 68k 3inch body lift, ET about 50 something!!!
BIG 6 farmer
Re: Can't remember
Post #2 by BIG 6 farmer » Mon May 13, 2013 3:47 am
I would say, no. But i could be wrong. :hmmm:
83 F 150 SB 4x4 300 six NP 4speed - - 1950 IHC L162 (1&1/2 ton?) - 87 & 88 T-Bird Turbo Coupes - 2000 Triumph Tiger , 76 Honda GL 1000 , & other toys and parts (& junk) -
THE FRENCHTOWN FLYER
Re: Can't remember
Post #3 by THE FRENCHTOWN FLYER » Mon May 13, 2013 12:13 pm
no - but three of the four water pump bolts do
Broncitis
Re: Can't remember
Post #4 by Broncitis » Mon May 13, 2013 10:17 pm
Thanks, the roller cam had 4 lobes go bad, I believe it is because the cam was reground and never re heat treated, unfortunately I will not be doing business with Schneider cams again, this was a disaster.
motzingg
Re: Can't remember
Post #5 by motzingg » Tue May 14, 2013 12:16 pm
pretty easy to check, take it to a machine shop and have them hardness test the lobes. not sure what they are supposed to be, but it seems like most cam manufacturers would rather do you right than have bad PR. getting your own test results, then contacting them would probably go a long way, most people that make performance parts have a lot of 'warranty' claims from idiots that install/tune things wrong.
seems pretty unlikely someone would forget to heat treat a cam...
80broncoman
Re: Can't remember
Post #6 by 80broncoman » Tue May 14, 2013 9:56 pm
Broncitis wrote:Thanks, the roller cam had 4 lobes go bad, I believe it is because the cam was reground and never re heat treated, unfortunately I will not be doing business with Schneider cams again, this was a disaster.
Heat treating a used/finished cam is very iffy.
They get bent is all kinds of directions when the heat gets to them. so much so that when they are new in processes the bearing journals
are left over size and finished AFTER heat treating.
OAPSE Union Member
Real men don't wear Bowties
Re: Can't remember
Post #7 by THE FRENCHTOWN FLYER » Tue May 14, 2013 10:37 pm
X2
Broncitis
Re: Can't remember
Post #8 by Broncitis » Wed May 15, 2013 2:17 am
Well I took it down to Colfax iron works and tried to have it Rockwell hardness tested, but he wasn't able to do the procedure, so Schneider asked me to send it to them and they looked at it and blamed it on endura x roller lifters from comp cams and said they would weld it up, heat treat it and regrind it, I just hope they know what they are doing and there's more to the story and I'm pretty tired of dealing with them and talking about it. Just a dam mess.
country fried 6
Re: Can't remember
Post #9 by country fried 6 » Wed May 15, 2013 3:17 pm
so what lifters would they recommend?
Broncitis
Re: Can't remember
Post #10 by Broncitis » Wed May 15, 2013 11:16 pm
They didn't recommend any lifter, because I'm the one that educated them on why I could not use there lifters, It has to be a forward facing linkbar and the endure x face outward on the link more than others I have found, unless you are sharp enough to know how to separate some of the others and put them back together below the block bosses, I machined the block bosses to just be able to drop the endure x in the holes with very little meat left and had to drill all the way into the water jacket and use studs for the side cover. I hope this makes sense. I think that FTF has done this separation below the bosses, but it is not easy and you better get it right and I'm sure he did.
Users browsing this forum: BigBlue94, Google [Bot] and 11 guests
