Powerblock TV to do a 300 six build up !!
Re: Powerblock TV to do a 300 six build up !!
Post #51 by bubba22349 » Sat Nov 02, 2013 2:22 am
You right, :bang: I stand corrected wonder what happened they usually show the second part the following week.
xrwagon
Post #52 by xrwagon » Sat Nov 02, 2013 5:19 am
i watched the show on there web site, part one that is, i was quite happy to see it, i even went and did a trick they showed on dead cylinders on my motor. As its got a mild miss and not really running right, i have a lifter noise also (200)
i cant wait for the show, will have to fit in between Sons of Anarchy and Walking Dead.
1967 XR Wagon Super Pursuit 1968 200/221 Head, Steel Shim headgasket/3spd Man/75 series Borg/Hi-Tech Headers/2.5 Collector 2.25 Hooker Aeroflow dumped at diff. PB 11.74 over Eighth 1/8 Mile
nightwatchman59
Post #53 by nightwatchman59 » Tue Nov 05, 2013 2:50 am
:bang: I work weird hours on the edge of "civilization"- and unable to view the second episode. A recap or pointer would be greatly appreciated. Thank you, guys.....
motzingg
Post #54 by motzingg » Tue Nov 05, 2013 8:26 am
the second episode hasn't been shown yet. I cant tell if its getting shown this weekend or not, looks like maybe not.
stu in wichita
Post #55 by stu in wichita » Tue Nov 05, 2013 9:15 am
xrwagon wrote: . . . i even went and did a trick they showed on dead cylinders on my motor. As its got a mild miss and not really running right, i have a lifter noise also (200) . . . .
What trick? Not sure what you're referring to. Thanks.
-Stu
Soldmy66
Post #56 by Soldmy66 » Tue Nov 05, 2013 10:42 am
I believe he is referring to the spray bottle method of determining which cylinder is not firing.
By spraying water on each primary header tube, you will identify which one is not firing because the header pipe temperature on the non-firing cylinder will be far less than the other tubes, and therefore the water sprayed on it will not vaporize as it does with the others.
80broncoman
Post #57 by 80broncoman » Tue Nov 05, 2013 10:48 am
Soldmy66 wrote:I believe he is referring to the spray bottle method of determining which cylinder is not firing.
X2 that is exactly right. You will know as soon as the water hits the last pipe.
It works just about as well on cast manifolds too.
OAPSE Union Member
Real men don't wear Bowties
THE FRENCHTOWN FLYER
Post #58 by THE FRENCHTOWN FLYER » Tue Nov 05, 2013 6:55 pm
I use the TSSSsssss method:
Saliva on a finger tip. Same principal. Test equipment is always with me.
Pass the Neosporin.
Last edited by THE FRENCHTOWN FLYER on Tue Nov 05, 2013 11:26 pm, edited 1 time in total.
CNC-Dude
Post #59 by CNC-Dude » Tue Nov 05, 2013 7:00 pm
Yeah, the spray bottle they used is the "white collar" approach. The FTF method is the good ole "blue collar" approach. :nod:
motzingg
Post #60 by motzingg » Wed Nov 06, 2013 10:10 am
i think 'white collar' is to use an IR thermometer or one of those handheld thermal cameras. Blue collar is spray bottle, and fingertip is plaid collar/ dirty wife beater.
using snow is the 'fur collar' method. I've used snow before on air cooled motorcycle engines.
stu in wichita
Post #61 by stu in wichita » Wed Nov 06, 2013 3:19 pm
I can see how that would identify a dead cylinder, but it wouldn't tell you much about an intermittent miss. I asked because of the mention of a "mild miss" and "not running right." The IR thermometer might indicate such a problem, because it would be few degrees cooler (depending upon how intermittent it is, LOL).
Thanks for the explanation.
-Stu
WerbyFord
Post #62 by WerbyFord » Tue Nov 26, 2013 10:20 pm
80broncoman wrote:I wasn't watching but listenting while i was here at my computer.
Next Week?? I'm gonna look online to see what i can find.
Nothing found yet
WOW I just found this thread. :o
Found Part 1 online, kinda sketchy, those look like older 76cc heads?
So based on what they said Im gonna assume
9,32cr at .030 deck
A 4bbl intake and what else, a 600 Holley (probably a $700 version)
Comp 268H cam at 218-218-110 .456 .456 as they noted
Headers, maybe full length if we are lucky
The WerbyFord Gonkulator says
Torq 331 at 3000
Powr 240 at 4300
I'm kinda glad they didnt run part 2 yet so I could try to predict it.
Then again, lets HOPE they run part 2. :mrgreen:
Fordman75
Post #63 by Fordman75 » Wed Nov 27, 2013 1:50 am
It's looks like you might never see part 2 by the way things are going. :rolflmao:
And even if you do, I seriously doubt the compression would be that high with pistons that short. You are talking about a piston that is almost 1/4" shorter then the stock ones.
Ted
54 Ford F100/F150 4x4
motzingg
Post #64 by motzingg » Wed Nov 27, 2013 8:21 am
don't forget they said they were throwing extra $$ into goodies because they saved cash on not needing the machine work...
lets hope they get silly with forced induction... is that too much to ask?
WerbyFord
Post #65 by WerbyFord » Wed Nov 27, 2013 11:06 am
Yikes I missed that "240 flattop" #1147 piston.
If so then the Gonkulator says
7.34cr [yawn] and .223 deck [yawn].
Torq 286 at 3000
Powr 210 at 4300
I hope they just goofed and think that piston will give near zero deck, maybe they delayed the show cuz they reordered some pistons that actually fit??? Hope so. Maybe we should contact them and tell em somehow? What a waste of a nice build.
motzingg
Post #66 by motzingg » Wed Nov 27, 2013 11:28 am
ha ha yeah, 7.3 cr would be good for a blown motor... maybe.
they said they were using the stock rods, and even did a bunch of work to them, but maybe they are using some trick longer rod out of another application.. v8 or something? 240 rods maybe?
Fordman75
Post #67 by Fordman75 » Wed Nov 27, 2013 1:30 pm
motzingg wrote:ha ha yeah, 7.3 cr would be good for a blown motor... maybe.
Not with cast pistons! :D
Nope not 240 rods. 240 Rods with 240 pistons on a 300 crank is not something that would work to well.
Ted
CNC-Dude
Post #68 by CNC-Dude » Wed Nov 27, 2013 1:40 pm
I used to have a close source that produced a lot of the Powerblock and Spike TV stuff at RTM productions. He said that their target audience is for the most part, totally clueless about tech stuff like this and they don't even know the difference between a camshaft and a crankshaft. So take that for what its worth about what you see on these type of shows.
Baron Von Ottomatic
Post #69 by Baron Von Ottomatic » Wed Nov 27, 2013 4:27 pm
CNC-Dude wrote:I used to have a close source that produced a lot of the Powerblock and Spike TV stuff at RTM productions. He said that their target audience is for the most part, totally clueless about tech stuff like this and they don't even know the difference between a camshaft and a crankshaft. So take that for what its worth about what you see on these type of shows.
Surely you jest? Spike TV is America's home for highbrow entertainment and serious f'n' knowledge.
CNC-Dude
Post #70 by CNC-Dude » Wed Nov 27, 2013 6:04 pm
Nope, wish I was joking! The average person that watches those shows knows very little about the subject matter of the show, thats why the get the ratings they do. He told me that most shows are still way over most guys knowledge level and they have to "dumb them down" so they aren't just completely lost. Things could have changed now, this was their thinking when it first came on the scene a little over 10 years ago. Just for giggles, do you know what Joe Elmore did before he came to Hot Rod TV? That will sort of give you an idea of the kind of people that host their shows....
Soldmy66
Post #71 by Soldmy66 » Wed Nov 27, 2013 8:53 pm
I had to look (from his bio):
For many years, Joe has hosted a Nashville PBS-based show called “Tennessee Crossroads” which is now one of the highest-rated shows of its kind in the country. Crossroads is a travel show that unveils fascinating people and places Joe finds on the two-lane highways of the mid-south. It’s earned several Emmy Awards and countless nominations.
As if that wasn’t enough, Joe also purses his longtime passion for music. Joe played bass in a variety of bands in his earlier years, including Bill Black’s Combo, a group formed by one of Elvis Presley’s first sidemen. He was immersed in the historic music of the “Memphis Sound” during its heyday and backed up some of the legends of rock and R&B.
More recently, Joe staged a clever “comeback” by combining his writing and singing talents with his affinity with the American car culture. The result: a one-of-a-kind CD called “Gearheads”, featuring songs with captivating car connections. He combined old-time favorites like “Mustang Sally” and “Little GTO” with originals he wrote that embrace his personal passion for hot rods.
Keeping in line with Joe’s mission of giving back, a portion of the proceeds from the CD are earmarked for the National Autism Association.
He was born in Paragould, Arkansas, received a Masters Degree in Communications, worked in film production, public relations, and TV news before heading to Nashville to amp up his career. Joe’s endless credit list includes PM Magazine, Opry Backstage on The Nashville Network and numerous TV specials, in addition to songwriting credits.
Joe loves interacting with people. And, at a podium, he can captivate an audience with his amazing experiences, inimitable insights and charming antidotes. Whether it’s talking about hot rods to a group of “car guys” or talking about his many Crossroads adventures to a general audience, he connects with listeners on a level that is genuine, engaging, uplifting and fulfilling.
CNC-Dude
Post #72 by CNC-Dude » Wed Nov 27, 2013 10:07 pm
Well my point was that while he does have a pretty impressive bio, he had/has zero automotive experience or knowledge prior to coming to RTM. So I guess if they think their viewers don't know the difference between a camshaft or a crankshaft, they might as well get a host that doesn't either. :rolflmao:
Fordman75
Post #73 by Fordman75 » Wed Nov 27, 2013 10:36 pm
CNC-Dude wrote:Well my point was that while he does have a pretty impressive bio, he had/has zero automotive experience or knowledge prior to coming to RTM. So I guess if they think their viewers don't know the difference between a camshaft or a crankshaft, they might as well get a host that doesn't either. :rolflmao:
I think it's been quite a while since Joe actually did much of the mechanical work on that show. They have a couple younger guys that do most of the work now. :thumbup:
Ted
stu in wichita
Post #74 by stu in wichita » Thu Nov 28, 2013 8:10 am
I never thought of hot rodding as a spectator sport, but that's what it has become. Same thing as the typical fan watching Monday night football who hasn't held a pigskin in twenty years (or maybe ever).
-Stu
Post #75 by THE FRENCHTOWN FLYER » Thu Nov 28, 2013 9:52 am
stu in wichita wrote:I never thought of hot rodding as a spectator sport, but that's what it has become. Same thing as the typical fan watching Monday night football who hasn't held a pigskin in twenty years (or maybe ever).
-Stu
And just like a football game, the Powerblock TV show will have its share of "Monday Morning Quarterbacks" to expound on what should have been done.
stu in wichita
Post #76 by stu in wichita » Thu Nov 28, 2013 10:46 am
THE FRENCHTOWN FLYER wrote: And just like a football game, the Powerblock TV show will have its share of "Monday Morning Quarterbacks" to expound on what should have been done.
Yup. :lol:
nightwatchman59
Post #77 by nightwatchman59 » Mon Dec 02, 2013 1:22 am
It's my fault. I apologize. When I watch the Redskins they lose. When I watch pwerblock, I'm left hangin'.... hope my stalking this site doesn't crash it.... my truck runs WAY better since I found this place!!!!! :thumbup:
motzingg
Post #78 by motzingg » Mon Dec 02, 2013 12:06 pm
Haha yeah... well you know ...the ad revenue drives programming, and smart people generally dont buy things just because they saw an add for it.
same reason the folks on shows like 'american chopper' spend more time yelling at each other, than actually doing something. idiots like to watch people yell at each other, and idiots buy stuff just because they see an ad for it.
same reason speed (which had huge viewership) went to a 'multi sport' format featuring college football and NASCAR... even though tons of people watch MotoGP... those people don't go out and buy motorcycle jackets just because they saw an add for them.
we're just lucky to have anything close to a show like 'powerblock' to watch.
WerbyFord
Post #79 by WerbyFord » Sat Dec 21, 2013 7:09 pm
Just a bump, does anybody know when the next episode (the dyno?) will be on or was on? :?
Fordman75
Post #80 by Fordman75 » Sat Dec 21, 2013 7:31 pm
Nope. :(
Ted
69halfcab
New Member
Post #81 by 69halfcab » Fri Jan 03, 2014 12:30 am
I have a 1969 halfcab with a 200. I want to swap to a 250 can I keep my transmission. any help appreciated thanks
Fordman75
Post #82 by Fordman75 » Fri Jan 03, 2014 2:11 pm
69halfcab wrote:I have a 1969 halfcab with a 200. I want to swap to a 250 can I keep my transmission. any help appreciated thanks
You'd have better luck posting your question in the small 6 forum.
Ted
Fordman75
Post #83 by Fordman75 » Tue Jan 14, 2014 6:26 pm
It looks like the second show of this build is going to be on this Sunday! :thumbup: And the third part the following week.
Ted
jack orchard
Post #84 by jack orchard » Tue Jan 14, 2014 8:15 pm
Watched the second show today @ 4:30 PM EST. They did block and head machining on another 300. Assembly will be the next week.
Fordman75
Post #85 by Fordman75 » Tue Jan 14, 2014 8:34 pm
I don't have NBC sports or CBS sports. So I have to wait for them to show it on Spike. :? :roll:
Ted
Post #86 by THE FRENCHTOWN FLYER » Wed Jan 15, 2014 10:24 am
I sure they did some more (off camera) head work.
chessterd5
Post #87 by chessterd5 » Wed Jan 15, 2014 7:43 pm
I don't have cable. Is there anyway someone could post a link or tell me where to go to watch the episodes on my computer? thanks.
Post #88 by bubba22349 » Wed Jan 15, 2014 7:54 pm
Fordman75
Post #89 by Fordman75 » Wed Jan 15, 2014 8:14 pm
bubba22349 wrote:Here you go link to 300 build :thumbup:
http://www.powerblocktv.com/episodes/HP ... inline-six
That's the old link, no more Powerblock. Now it's Powernation and the show is Engine Power. :roll: Here's the new links. The videos won't be posted for a week or two though. :(
http://powernationtv.com/shows/engine-power
http://powernationtv.com/episode/EP2014 ... -skool-six
http://powernationtv.com/episode/EP2014 ... end-tricks
Ted
motzingg
Post #90 by motzingg » Thu Jan 16, 2014 1:04 pm
SUNDAY
SUNDAY
SUNDAY
darn, bummed that i missed it... have to wait for them to put it online
blmhawkeye
Post #91 by blmhawkeye » Fri Jan 17, 2014 10:29 am
They've posted the equipment theyre using but not intake manifold....
Fordman75
Post #92 by Fordman75 » Fri Jan 17, 2014 10:38 am
blmhawkeye wrote:They've posted the equipment theyre using but not intake manifold....
The way the carb was mounted in the video clip I saw of it on the dyno. I would say it's the Offy DP. :cry: And it was a holley vac. secondary 4V. So I'm guessing they used the 390 cfm holley. :?
Here's the video clip. The 300 starts on 0.33 of the video.
https://www.youtube.com/watch?v=pROSdy7t250
Ted
blmhawkeye
Post #93 by blmhawkeye » Fri Jan 17, 2014 12:42 pm
It is indeed a holley from the looks of it but i wouldnt think they would put a dp on it running a 268 comp cam
Fordman75
Post #94 by Fordman75 » Fri Jan 17, 2014 1:07 pm
blmhawkeye wrote:It is indeed a holley from the looks of it but i wouldnt think they would put a dp on it running a 268 comp cam
I wouldn't run a dp on any 300 period! :lol:
Ted
country fried 6
Post #95 by country fried 6 » Fri Jan 17, 2014 3:08 pm
looks like they ditched the pinned press-in rocker studs for screw in studs.
Fordman75
Post #96 by Fordman75 » Fri Jan 17, 2014 3:47 pm
I'm just hoping they ditched the 240 flat top pistons!! :roll: :lol:
Ted
80broncoman
Post #97 by 80broncoman » Fri Jan 17, 2014 9:03 pm
in the parts list it shows a Holley 470CFM truck avenger carb listed. on the new website.
OAPSE Union Member
CNC-Dude
Post #98 by CNC-Dude » Fri Jan 17, 2014 11:02 pm
Fordman75 wrote:I'm just hoping they ditched the 240 flat top pistons!! :roll: :lol:
I guess the dyno test will tell the tale. If its not padded.
Fordman75
Post #99 by Fordman75 » Fri Jan 17, 2014 11:58 pm
Well that's better then the 390. :D
Ted
Baron Von Ottomatic
Post #100 by Baron Von Ottomatic » Sat Jan 18, 2014 8:28 am
The second show is airing at 8:30 a.m. tomorrow, Sunday Jan 19. Set your DVRs to record.
http://www.powernationtv.com/schedule/
Users browsing this forum: No registered users and 11 guests
