2 barrel carb linkage
SeaBee
Post #1 by SeaBee » Sun Dec 22, 2013 9:57 am
ok I installed my clifford intake and split exhaust manifolds on my 83 300 six that i am installing in a 1972 ford f100 . where do I start figuring out how to connect linkage. I have the bracket that bolts to the fire wall with a cable attached to that . pics if possible
BIG 6 farmer
Re: 2 barrel carb linkage
Post #2 by BIG 6 farmer » Sun Dec 22, 2013 3:50 pm
If I remember correctly ? :hmmm: Ford car or light truck, 71? or later. With 2 V Carb. Some had a bracket for throttle cable that mounted on back 2 studs for Carb. Others had bracket that mounted to Intake (V8 Engine). If using the later, would have to fab. bracket to mount cable @ carb. I think most cable/pedal assy. from 71? to 84-85? with 2V carb., could be made to work. :hmmm: A trip to the salvage yard needed. :nod: Maybe some fab. work (welding?) for bracket @ Carb... Im sure others on here can add/improve on my thoughts. :D
83 F 150 SB 4x4 300 six NP 4speed - - 1950 IHC L162 (1&1/2 ton?) - 87 & 88 T-Bird Turbo Coupes - 2000 Triumph Tiger , 76 Honda GL 1000 , & other toys and parts (& junk) -
80broncoman
Post #3 by 80broncoman » Sun Dec 22, 2013 4:59 pm
on my 80 bronc I went to auto Zone a bought a throttle cable for a 85-86 F150 with a 5.0 EFI engine
THat way you get a much longer cable to work with. I also used a Spectre? Aftermarket carb throttle cable mount bracket.
OAPSE Union Member
Real men don't wear Bowties
nightwatchman59
Post #4 by nightwatchman59 » Mon Dec 23, 2013 1:38 am
Awesome tip Broncoman! I'm lucky to have caught this...right on time! THANKS and MERRY CHRISTMAS EVERYONE!
SeaBee
Post #5 by SeaBee » Mon Dec 23, 2013 4:40 pm
" I also used a Spectre? Aftermarket carb throttle cable mount bracket." Where did you buy this from? Thanks
BIG 6 farmer
Post #6 by BIG 6 farmer » Tue Dec 24, 2013 5:08 pm
This is why this Forum is so great. :thumbup: Did not know that after market bracket was offered...
Harte3
Post #7 by Harte3 » Tue Dec 24, 2013 6:24 pm
Some parts houses, speed shops, Summit, etc., carry the brackets.
Nashtooth
Post #8 by Nashtooth » Tue Dec 24, 2013 9:42 pm
Isn't the problem the orientation of the carb being 90 degrees off the long way relative to a bent 8 2v? My 390 holley pulls from the back like a V8 but a two barrel would seem to need a lot more cable. I'm interested since this is my next move, so I can close the hole in my van's doghouse which makes my electric choke a passenger, in the cab with me. Not so good in winter. Meaning now.
SeaBee
Post #9 by SeaBee » Wed Dec 25, 2013 9:06 am
I would like someone to post a pic of this set up if possible
80broncoman
Post #10 by 80broncoman » Wed Dec 25, 2013 9:35 pm
SeaBee wrote:" I also used a Spectre? Aftermarket carb throttle cable mount bracket." Where did you buy this from? Thanks
Autozone had it on the shelf. If I remember Right it had quite a few adjustments on it as well.
OAPSE Union Member
Users browsing this forum: buckingbronco, THE FRENCHTOWN FLYER and 19 guests
