THE 240 / 300 WHERE ELSE WERE THEY USED? OTHER APPLICATIONS
THE FRENCHTOWN FLYER
Post #1 by THE FRENCHTOWN FLYER » Sun Dec 06, 2015 11:08 pm
Aside from the typical automobile and truck applications, I've been mulling over other places I've seen or heard of our venerable inline sixes being used. So lets hear and see (if you've got pics) of other applications that used the 240 or 300 engines, other than cars or trucks.
Some applications I've heard of:
AIRPORT TUGS
WOOD CHIPPERS
BOATS
MARINE LIFTS
SIDEWALK SNOW PLOWS
SNOW CRAWLERS
STATIONARY GENERATORS
WELDERS
IRRIGATION PUMPS
AIRCRAFT
I'll start it off with this pic of a CONCRETE PUMP I took at a car show in SoCal:
arse_sidewards
Re: THE 240 / 300 WHERE ELSE WERE THEY USED? OTHER APPLICATI
Post #2 by arse_sidewards » Mon Dec 07, 2015 3:26 am
Combine harvester
http://www.yesterdaystractors.com/cgi-b ... &th=604323
These were off the shelf industrial engines for 30yr. There's tons of custom applications out there running stationary Ford 300s for power.
1994 F150 4x4 8ft, engine is basically stock.
66" leafs, extended radius arms, lockers in both ends, nothing special.
lstpan
Post #3 by lstpan » Mon Dec 07, 2015 10:50 am
Use to see Alott of them out west in az pumping water. My engine guy also rebuilt a bunch for a local concrete guy
Post #4 by THE FRENCHTOWN FLYER » Mon Dec 07, 2015 10:58 am
I guess I am most interested in commercial applications, not so much one-off custom uses. But hey, its all good.
Fordman75
Post #5 by Fordman75 » Mon Dec 07, 2015 8:00 pm
Here's a waterpump powered by an industrial 240 I picked up a few years back.
Ted
54 Ford F100/F150 4x4
Post #6 by THE FRENCHTOWN FLYER » Mon Dec 07, 2015 9:03 pm
Fordman75 wrote:Here's a waterpump powered by an industrial 240 I picked up a few years back.
That's not a water pump - its DynoInACan.
Last edited by THE FRENCHTOWN FLYER on Mon Dec 07, 2015 10:16 pm, edited 1 time in total.
161henry
Post #7 by 161henry » Mon Dec 07, 2015 10:03 pm
Airplanes??? Please tell me more...
Post #8 by THE FRENCHTOWN FLYER » Mon Dec 07, 2015 10:19 pm
Somebody on this board was building one in a replica biplane. It wasn't commercial - it was an experimental. ANYBODY REMEMBER HIS SCREEN NAME?
blmhawkeye
Post #9 by blmhawkeye » Tue Dec 08, 2015 1:21 am
I can confirm that the small block 170 and 200 were used in the airplane tugs. Motor in my father's falcon came from one of them when he was a mechanic at the airport
Fordman75
Post #10 by Fordman75 » Tue Dec 08, 2015 1:27 am
blmhawkeye wrote:I can confirm that the small block 170 and 200 were used in the airplane tugs.
So were 300's. I just about bought a couple of those too. :D
Ted
Post #11 by bubba22349 » Tue Dec 08, 2015 2:44 am
THE FRENCHTOWN FLYER wrote:Somebody on this board was building one in a replica biplane. It wasn't commercial - it was an experimental. ANYBODY REMEMBER HIS SCREEN NAME?
I think his screen name was Von Writter, and that he was building a Fokker DVII using a 300 for power. :nod:
CoupeBoy
Post #12 by CoupeBoy » Tue Dec 08, 2015 10:17 am
Two summers ago, I picked up an Industrial 300 and a Funk Reverse-O-Matic at work.
Industrial 300 at work (in the scrap bin! gasp) -- FordSix Forum
It made it into the back of my truck, pretty sure the hood took a beating.. :rolflmao:
The guys at work lifted it with a tele-handler
And dropped it right in.
I found out what it came out of finally.. And Ingram 9-2800 wheel packer
This is what remains of the packer at work.
I also found out why they removed it... They didn't use it very often and they said it was hard to keep in good running condition. They claim it is easier to have it loaded with weight and use another vehicle to pull it, something that they use more often :roll: They did say it was in running condition when they pulled it.
I've also got an Industrial 200, Dad bought it at an auction, I can't for certain say what it came off, but likely it was a swather.
Ford 200 Industrial -- FordSix Forum
If I ever needed to run a motor (144/170/200) outside a car, this thing has the perfect frame, fuel tank over the engine, bellhousing adapter, and radiator..
I had bought these off eBay a while back.
Looks familiar doesn't it?
1970 170/C4
1967 200/C4
1975 250/flexplate
1975 300/flywheel
CoupeBoy
Post #13 by CoupeBoy » Tue Dec 08, 2015 11:57 am
This is interesting.
Tech Tip # 152: Ford 300 Industrial Engines -- Foley Engines
A lot of people are running Ford 300 industrial engines in wood chippers, airport tugs, sidewalk snow plows, marine travel lifts, and other industrial applications. The Ford 300 industrial engine, also known as the CSG649i engine, is a rugged workhorse. To survive in the industrial work place these engines have upgraded components including hardened cast iron timing gears, two groove harmonic balancers, a heavy duty water pump with a .75" diameter shaft to accommodate a larger bearing, severe duty hypertechnic pistons, full sump 6 quart oil pan and other upgrades.
And the interesting part
We can help. We are now stocking factory remanufactured Ford 300 CSG649i industrial engines. These are severe duty engines. Not warmed over passenger car engines. They have all of the industrial components including the cast iron timing gears, brand new camshaft and lifters, new oil pump and new oil pump steel drive rod, and other upgrades.
The website has a few links to other Ford Industrial engine information.
lstpan
Post #14 by lstpan » Tue Dec 08, 2015 12:14 pm
Yep this is it, they are everywhere in the sw part of the U.S.
tom954x4
Post #15 by tom954x4 » Tue Dec 08, 2015 2:47 pm
Industrial 300s are also used to power augers for well drilling rigs.
1995 F-150 XL, 300-6, 4x4, ex-cab, sb, 3.08 5-speed, 2 1/2 in. exhaust w/flowmaster 50, MSDignition failed with no warning, now out, canopy, 179,000 + miles. Gone but not forgotten 1965 F-100 240 3spd lwb "the green hornet"; 1960 F-250 4x4, 223 six, 4sp with wrap-around rear window, two-tone paint, overhead camper.
Tow vehicle: 2012 F-250 4x4 6.7 diesel XLT s/c lwb
woodbutcher
Post #16 by woodbutcher » Tue Dec 08, 2015 8:27 pm
:beer: Hi FTF.I remember a 40ft wood hull commercial fishing boat that had THREE 300 6`s.Two for the props
and one to run the generator.
Good luck.Have fun.Be safe.
Leo
Otto von Bismarck
edgewood bronco
Post #17 by edgewood bronco » Tue Dec 08, 2015 9:39 pm
This isn't quite in 'other' applications, but 300s powered UPS delivery trucks until Ford stopped making them. My dad got four from scrapped trucks about 15 years back.
62 F100 223
66 Bronco 200; autolite 2100 2 bbl conversion: Lovin' it!
Post #18 by THE FRENCHTOWN FLYER » Tue Dec 08, 2015 11:15 pm
I recently took a ride in this Bombardier snowplow. It is powered by a 300. Driving it was a lot like riding one of those mechanical bulls in a saloon. Twin sticks were hard to get the feel for. I did several wheelies - I mean "trackies".
edgewood bronco
Post #19 by edgewood bronco » Wed Dec 09, 2015 10:09 am
That's COOL!!!
62 F100 223
CoupeBoy
Post #20 by CoupeBoy » Wed Dec 09, 2015 10:19 am
I forgot about those. All the ones I've seen locally, like this one
1972 Bombardier 200 Sno Vehicle with 11' Boss v-plow - $25000 (AVON)
Have the small six
A same as this one from a couple years ago at a local car show.
f100owner
Post #21 by f100owner » Thu Dec 10, 2015 11:52 am
edgewood bronco wrote:This isn't quite in 'other' applications, but 300s powered UPS delivery trucks until Ford stopped making them. My dad got four from scrapped trucks about 15 years back.
I was told the 300 is still powering UPS trucks. One of the sources I was considering for rebuilt engines made a reference that a lot of their work was rebuilding 300s for UPS.
Texas;
1971 F100 - 240CID
2016 Ford Expedition
2015 Ford Fusion
2016 Harley - Ultra Limited.
Fordman75
Post #22 by Fordman75 » Thu Dec 10, 2015 12:15 pm
f100owner wrote:I was told the 300 is still powering UPS trucks. One of the sources I was considering for rebuilt engines made a reference that a lot of their work was rebuilding 300s for UPS.
All the ones that come to my house are diesel powered.
Ted
edgewood bronco
Post #23 by edgewood bronco » Thu Dec 10, 2015 9:49 pm
that's my understanding. They went to diesels. But apparently not in all markets...
62 F100 223
1986F150six
Post #24 by 1986F150six » Mon Dec 14, 2015 4:02 pm
Post #25 by THE FRENCHTOWN FLYER » Mon Dec 14, 2015 5:45 pm
That unit looks nice. I wonder how many hours is on it? I also wonder why 240's were frequently used as opposed to a 300?
1964f100240
Post #26 by 1964f100240 » Mon Dec 14, 2015 10:35 pm
i work on some rail car movers that use 300s there from the 70s up to the 90s i had one that had a cracked ext manifold i tried to put a header on it but bnsf wouldnt go for it lol.
1986F150six
Post #27 by 1986F150six » Tue Dec 15, 2015 9:17 am
THE FRENCHTOWN FLYER wrote:That unit looks nice. I wonder how many hours is on it? I also wonder why 240's were frequently used as opposed to a 300?
Hmmm? Perhaps the 240s were less expensive? Or, could it be that the 240 had ample power/torque to spin the generator at the 1800 RPM threshold and would consume less fuel than would the 300?
Post #28 by THE FRENCHTOWN FLYER » Tue Dec 15, 2015 10:15 am
The Ford engineer who was the liason between marine and industrial customers and Ford powerplants lives not too far from me. I'll ask him about the 240 / 300 split when I see him again.
arse_sidewards
Post #29 by arse_sidewards » Tue Dec 15, 2015 12:30 pm
That's basically the same piece of equipment as one I posted in the eBay finds section a month or so back. The one I saw had a 300.
When you order a semi-custom piece of equipment like a pump there's a lot of leeway for spec'ing different configuration options including engines, especially ones that are externally identical or equipment that isn't directly coupled to the engine. I'm casually looking for a junk boat with an inboard SBF so I can do basically that (300 on a skid with a drive flange). The original buyer of the gen-set could have probably got a 302 or 351 in for the difference in price plus markup. Makes sense if you've got a fleet of SBFs and want your generator to use the same tune up parts. As for 240/300, probably a cost or fuel consumption at idle thing.
tom954x4
Post #30 by tom954x4 » Tue Dec 15, 2015 1:16 pm
Post #31 by bubba22349 » Tue Dec 15, 2015 2:03 pm
:mrgreen: Really nice, I sure wouldn't mind having a 240 or 300 Generator setup (running on NG would be great) and use it for backup power here! :nod:
manglass
Post #32 by manglass » Tue Dec 15, 2015 4:35 pm
I don't have any pictures but the 80's 45kw Onan that we had installed at our local ambulance building (in NY) had a Ford 300ci 6 cyl. It ran on natural gas, right off the municipal supply.
Lou Manglass
tom954x4
Post #33 by tom954x4 » Wed Dec 16, 2015 1:04 pm
I think the difference between using a 240 and a 300 in a generator would be the max rating of the generator. Note that in the two links here the 300 has a 35 kw rating and the 240 has 30 kw rating. The engines have different power outputs at 1800 rpm or wherever it is governed at. Use the smaller displacement engine if it meets the generator specs.
arse_sidewards
Post #34 by arse_sidewards » Wed Dec 16, 2015 1:32 pm
tom954x4 wrote:I think the difference between using a 240 and a 300 in a generator would be the max rating of the generator. Note that in the two links here the 300 has a 35 kw rating and the 240 has 30 kw rating. The engines have different power outputs at 1800 rpm or wherever it is governed at. Use the smaller displacement engine if it meets the generator specs.
35kw is 46hp. Either engine can easily make that at 1800rpm. The 300 I saw was 20-someting kw.
Post #35 by THE FRENCHTOWN FLYER » Wed Dec 16, 2015 4:37 pm
Assume 50% mechanical/electrical efficiency.
arse_sidewards
Post #36 by arse_sidewards » Thu Dec 17, 2015 12:23 pm
THE FRENCHTOWN FLYER wrote:Assume 50% mechanical/electrical efficiency.
When I said 100hp I meant at the wheels. A vehicle has tons more rolling resistance from the drive-train than a direct drive gen-set so I figure .
Is that 50% number for an alternator? Modern alternators usually peak around 60% at a particular RPM. There's efficiency sacrifices for being so durable and operating at a wide range of speeds. At peak output (which is when you need max input HP) generator of a few KW or more should be 70%-90% depending on size and design. I can see 50% at light/medium load conditions but as long as the engine can keep up at peak it can keep up at idle.
A bone stock carb'd 300 with no accessories except a fan on a dyno makes 70-80 flywheel horsepower at WOT between 1600 and 2000rpm. Why the EPA couldn't be bothered to test a popular industrial engine at 1800rpm (engine speed for 60hz using a 4-pole generator) is beyond me.
If you assume 60% efficiency and 35kw output at 1800rpm you get 76hp input. If you assume 80% efficiency you get 57hp input. Granted I don't know much about the 240's torque curve but to me that says a 240 should be able to power an efficient 35kw gen-set but you'd need a 300 to power an inefficient one.
Rusty_Old_F250
Post #37 by Rusty_Old_F250 » Thu Dec 17, 2015 1:45 pm
What brand/model of welder ran a 240/300 in it? That had to be a big machine, the new(er) (1970's) Hobart GR303's used a 170 small six and they are rated at 300 amps 100% duty cycle, which is some SERIOUS power for welding, put it this way, there isn't much you can't weld with 300 amps. I can only image how many amps a 300 powered rig could crank out!
By the way, if anyone knows where I might be able to find a 170 powered GR303 in Washington State, running or not, with a trailer, let me know.
Sam
crackdhead
Post #38 by crackdhead » Mon Jan 11, 2016 11:44 am
Haha what a coincidence... http://lancaster.craigslist.org/for/5334725489.html
Using a tracked vehicle to plow snow on pavement seems so counter intuitive to me though like it seems that a more solid tread with bigger blocks would work better on pavement than an open one
Post #39 by THE FRENCHTOWN FLYER » Mon Jan 11, 2016 1:38 pm
That looks similar to the one in my Dec 8 post, except the one I posted was a 300 with a C6 trans.
powerband
FSP Moderator
Post #40 by powerband » Mon Jan 11, 2016 1:42 pm
In the mid 70's I worked as a maintenance mechanic at a the mountaintop Ski-Minne ski areas of the Lake Minnewaska Mountain House in the Shawangunk Mountains of NY's Hudson Valley. I was hired specifically because I was familiar with air cooled VW motors that the "Hedco" snow makers used and the Ford six's the Snow Trackers and Trail Groomers used.
Image . Image . Image
crackdhead
Post #41 by crackdhead » Mon Jan 11, 2016 5:03 pm
Thats cool, is that you hiding around the corner of the machine with the my god looks like 4 foot wide tracks?
So now Im curious how they work? On the model FTF drove I assume they just used a foot throttle like a car and the 2 sticks operated a brake on each side of a standard open differential?
Like how you help steer a backhoe or how the wheelstand racers steer the car down the track?
arse_sidewards
Post #42 by arse_sidewards » Mon Jan 11, 2016 7:57 pm
FWIW a 4spd and a C6 with the shorter tail housing are about the same length. That would be interesting in a snow machine.
crackdhead wrote:Haha what a coincidence... http://lancaster.craigslist.org/for/5334725489.html
Those machines are basically tractors optimized for snow. How well it grips pavement after it pushes all the snow away was a pretty low priority when it was designed. The paddle like tracks work great in deep snow and apparently good enough for plowing but it's not the first thing I'd pick as a dedicated plowing rig and it is for sale after all.
Crocodile
Post #43 by Crocodile » Mon Jan 11, 2016 10:37 pm
The company I work (telephone co-op) for has about 8 gen sets (Onan, mostly 35 KW) powered by 300 sixes. They power the central offices when commercial power is interrupted. They all run on propane, and are kept warm 24/7 using a block heater, as they jump right to full load at operating speed as soon as a power loss is sensed. After 100 hours, when we change the oil, it still looks like new since there are relatively few contaminants or soot built up from running propane. The spark plugs also appear as new. Some of these sets were new in the late 80's or early 90's, and they still run point distributors.
crackdhead
Post #44 by crackdhead » Tue Jan 12, 2016 9:29 am
arse_sidewards wrote:Those machines are basically tractors optimized for snow. How well it grips pavement after it pushes all the snow away was a pretty low priority when it was designed. The paddle like tracks work great in deep snow and apparently good enough for plowing but it's not the first thing I'd pick as a dedicated plowing rig and it is for sale after all.
I forgot about plowing snow on top of snow for grooming skiing mountains instead of plowing it clean to pavement woops
arse_sidewards
Re: THE 240 / 300 WHERE ELSE WERE THEY USED? OTHER APPLICATIONS
Post #45 by arse_sidewards » Sun Feb 05, 2017 1:13 am
Post #46 by THE FRENCHTOWN FLYER » Mon Feb 06, 2017 11:41 am
Wow that is way cool. Two things that surprise me is the 82 gallon hydraulic capacity and the 29 mph top speed. Thanks for posting.
arse_sidewards
Post #47 by arse_sidewards » Mon Feb 06, 2017 12:04 pm
THE FRENCHTOWN FLYER wrote:Wow that is way cool. Two things that surprise me is the 82 gallon hydraulic capacity and the 29 mph top speed. Thanks for posting.
I forget the rule of thumb for resevoir size but when you consider that that machine probably has close to 10gal in cylinder displacement 82gal sounds on the small side for doing a 180 turn and full extend/retract 8+hr/day.
A quick Google tells me that most have been re-powered to 4-53s. Most machinery like that is a simple engine + trans in front of a divorced "T-case" (I'm using the term loosely) that provides the necessary power take offs it's a simple matter of "if it fits it goes". There's a guy on Pirate 4x4 who put a 302 and (IIRC) C6 in a front end loader.
tnab1970
Post #48 by tnab1970 » Fri Feb 17, 2017 11:28 pm
I have seen several 300 Ford powered Oil / Gas well pumping units. We built 4 units in 2012 , customer supplied us with used skids all engines were 300 Fords. They each had a gear driven Hyd. Pump mount bolted on where a bell housing would be. All ran on Natural Gas or Propane.
arse_sidewards
Post #49 by arse_sidewards » Mon Feb 20, 2017 11:39 pm
Dunno what it's out of but here's a 300 that saw marine use.
https://boston.craigslist.org/sob/hvo/6010806311.html
tom954x4
Post #50 by tom954x4 » Tue Jun 06, 2017 1:55 pm
I just saw a Marine Travellift (30 ton hoist with slings for lifting and carrying boats) with a ford six, could be a 240 or a 300. The engine powers hydraulics to lift and lower the load and propel the lift + boat forward and back (slowly, I might add).
Did the 240 come in an Industrial version? I could not see if this engine had the HD manifolds.
Users browsing this forum: Google [Bot], jgregg13 and 33 guests
