I got this motor from a friend who said it was out of a van with under 100,000 miles on it. I have put on at least another 90-100 k on it. So I figured I should see what condition its in.
cylinder# 6 150 Dry 160 Wet
cylinder# 5 152 Dry 170 Wet
cylinder# 4 155 Dry 160 Wet
cylinder# 3 150 Dry 150 Wet
cylinder# 2 170 Dry 170 Wet
cylinder# 1 152 Dry 160 Wet
<<< New Site Update >>>
What do you think of these compression numbers?
In-lines we trust
86 f150 300 efi with advanced stock cam. Np435, Dana 60/ 10.25, 35" BFG's, four link front suspension with 12" travel fox coil overs, custom deaver leaf pack in the rear.
Re: What do you think of these compression numbers?
Hi, I'd say the numbers are pretty good. Why are you concerned?
1966 Ford Mustang - 289 V8
- Registered User
That's ready for another 100,000
Sam
Sam
I was thinking about switching the stock cam for a crane 901, but I did not know the condition of this engine.
What is a fresh motor in stock form supposed to put out?
In-lines we trust
Hi, If that was mine I would think about giving it rings and bearings, with a light hone and plasti gauge the crank. Along with going over the head. Good luck
Hi Wesman07,
If you have an analog gauge, what oil pressure are you seeing at cruise and hot idle?
1995 F-150 XL, 300-6, 4x4, ex-cab, sb, 3.08 5-speed, 2 1/2 in. exhaust w/flowmaster 50, MSDignition failed with no warning, now out, canopy, 179,000 + miles. Gone but not forgotten 1965 F-100 240 3spd lwb "the green hornet"; 1960 F-250 4x4, 223 six, 4sp with wrap-around rear window, two-tone paint, overhead camper.
Tow vehicle: 2012 F-250 4x4 6.7 diesel XLT s/c lwb
I don't know what my oil pressure is but I know the pump is new.
I think I'll save the new cam for a fresh motor and just advance this one
In-lines we trust
Wesman07 wrote:I think I'll save the new cam for a fresh motor and just advance this one
What are you going to use to advance the cam?
A cloyes timing set. Is there another option?
In-lines we trust
Wesman07 wrote:A cloyes timing set. Is there another option?
Mr Gasket 987G offset cam key.
It will get you 4 degrees at the crank when you use it with the cam gear.
The Mr Gasket 988G will get you 8 degrees at the crank when used with the cam gear
You would recommend degreeing the original gears over replacing the set?
I would imagine that would be a heck of a lot easier to do, but shouldn't I be concerned about the fiber gear?
Also, how much should I go? Aren't there diminishing returns after a certain point?
In-lines we trust
Wesman07 wrote:You would recommend degreeing the original gears over replacing the set?
You are right concerning replacing the fiber gear.
I would get a steel replacement set and use the offset key.
I'm not real confident with the Cloyes aluminum cam gear either. There have been a few here that have had noise problems.
I would go 4 degrees advance. If you go 8 then you lose some horsepower but more importantly the engine becomes more prone to detonation.
Users browsing this forum: No registered users and 13 guests
