300 distributor issue
64falconsix
Post #1 by 64falconsix » Fri Mar 24, 2017 10:33 pm
My son's f150 has had 2 distributors seize in the past 18 months..... does someone have a block that they could check and let me know about the hole circled in the pic.....does it open to the crank case or oil galley.....how deep is it does anyone have a bare block that can take some pics.....
64 falcon 2dr 200 C.I. .040 decked ,comp. 260 .440, C.I. adjustable timing chain w/ 79 log head 52.cc , offy w/ triple webers , Clifford header , D.U.I. , C/4 2,200 stall , Transgo Stage 2 reprogramming kit , 7 1/4" with 3.20 gears. NX, N2O 75HP shot.
10.29@ 61.91 M.P.H. in the 1/8th mile. 4/12/13
jason832
Re: 300 distributor issue
Post #2 by jason832 » Fri Mar 24, 2017 10:48 pm
I have 2 blocks sitting on my shop floor. If nobody else answers in a few days I'll have the best look I can when I'm there next.
The teeth on the cam look a small bit worn to me but it's hard to tell, or is this a picture you got from elsewhere... I'd roll it over a little at a time and make sure it's good.
pmuller9
Post #3 by pmuller9 » Fri Mar 24, 2017 11:03 pm
There is a 5/16" diameter vertical hole in the lifter gallery about 3/8" back from the gallery cover that gravity feeds oil to the cam gear.
The hole in the distributor bore is angled upward and tees into that same oil supply hole.
If the hole from the oil gallery is blocked it will also cause wear on the cam gear as well as damage to the distributor.
tnab1970
Post #4 by tnab1970 » Fri Mar 24, 2017 11:21 pm
Just checked bare block, approx .125" hole leading to the 5/16 that Pmuller9 just posted. Another thing to look at is different length oil pump drive rods and the different depth on the bottom of the distributor where the drive rod goes into it. We have had to shorten them before when we changed distributors.
64falconsix
Post #5 by 64falconsix » Fri Mar 24, 2017 11:43 pm
This is a pic my son sent me over a year ago.....of the engine in question.....I was unable to look at it because of time and distance...... he took it to a shade tree mechanic who tells him the oil galley feed the distributor is blocked.... not that familiar with the 300 but I know my 200 and 302 are splash oiled..was wondering if the circled hole in the pic was just an opening into the crank case to access splashed oil or pressurized oil from the galley........schematic of the 300 oil system does not show that opening....oiling the distributor or gear......mechanic tells him he may have to pull the engine to unclog the oil feed to the distributor. .......does not sound right to me......last distributor lasted about 16 months...
pmuller9
Post #6 by pmuller9 » Sat Mar 25, 2017 12:33 am
Just remove the lifter gallery side cover and run a 5/16 drill bit down the hole towards the cam gear.
Then run a Q tip with solvent up the distributor hole till it hits the 5/16 hole. The small distributor hole is 1.25" long.
64falconsix
Post #7 by 64falconsix » Sat Mar 25, 2017 5:48 pm
Thankyou all for the quick responses. ........back on track .....my son will pull the side cover and check the drain hole......
Users browsing this forum: No registered users and 101 guests
