300 rebuild project
pmuller9
Re: 300 rebuild project
Post #201 by pmuller9 » Fri May 04, 2018 10:30 am
brandoncw wrote:ok, yeah that makes sense. Ill get either and adjustable waste gate to replace the one i have now or get and external one, along with a blow off valve. ~10 psi is the max pressure i should use right?
I would start with 10 psi but with forged pistons and a low compression ratio and intercooler I see no reason not to go to 15 psi if you need the extra torque.
brandoncw
Post #202 by brandoncw » Fri May 04, 2018 10:59 am
About $600 for a set of those right?
Skilled labor isn't cheap, Cheap labor isn't skilled.
pmuller9
Post #203 by pmuller9 » Fri May 04, 2018 1:08 pm
brandoncw wrote:About $600 for a set of those right?
I haven't checked this year but the last price was less than $550 for a set of 4032 alloy forged pistons and pins from Autotec.
The pistons using the Ford .975" pin cost $40 extra.
What connecting rods do you plan to use?
brandoncw
Post #204 by brandoncw » Fri May 04, 2018 1:33 pm
I might use stock, maybe custom. All depends on my full time pay check.
I remeber seeing a set of nice rods on another build that was the same width all the way down. But i assume they were out of my price range
brandoncw
Post #205 by brandoncw » Tue May 08, 2018 12:30 pm
Nearly done. Just gotta drill and tap holes for studs and fittings and powder coat it. My measurments i got must have been for the hole spacing of the 2100 because my mounts were a little big, but it still looks good to me ans ought to work just fine
pmuller9
Post #206 by pmuller9 » Tue May 08, 2018 2:35 pm
Did you do the 4 threaded holes for the 1/8" fittings?
brandoncw
Post #207 by brandoncw » Tue May 08, 2018 2:39 pm
pmuller9 wrote:Did you do the 4 threaded holes for the 1/8" fittings?
Thats one if the things i need to do. This is my last week of school and i wouldnt be able to get the fittings and tap till next week. So ill just drill the holes with a vaccum by the bit to collect any shavings. Then the whole thing is gonna get a wash before its powder coated too
pmuller9
Post #208 by pmuller9 » Tue May 08, 2018 2:42 pm
Is there a spot at least 1/4" thick for enough threads to support the fittings?
brandoncw
Post #209 by brandoncw » Tue May 08, 2018 5:11 pm
pmuller9 wrote:Is there a spot at least 1/4" thick for enough threads to support the fittings?
yes, on the very back I stacked a 1/4" plate on top of the 1/8" sheet aluminium and welded it on
brandoncw
Post #210 by brandoncw » Wed May 16, 2018 8:26 am
Well I got a new phone, drove around a couple hours looking for the old one and no luck. This new one takes much better pics though :thumbup:
I got my engine block back yesterday. And my intake painted too.
P.s. check out my other thread in mustang corral about possibly buying this 65 mustang
old28racer
Post #211 by old28racer » Wed May 16, 2018 8:35 pm
If I might ask what is your L - W - H for your plenum?
Are you planing to run two 2100 Autolite carbs?
Bad Day Racing Is Better Than A Day In The Stands :mrgreen:
brandoncw
Post #212 by brandoncw » Thu May 17, 2018 8:16 am
old28racer wrote:If I might ask what is your L - W - H for your plenum?
I don't remember exactly but I believe I went slightly over 4 inches on the top 3.5 on long side, 2.5 on short side and 4 on the bottom.
Also I have my one carb mounted up on two studs I ended up having to make from 3/8 "all thread". Meaning I also had to drill out the holes on the carb slightly too.
Pretty tight clearances but the carb fits on there
brandoncw
Post #213 by brandoncw » Fri Aug 10, 2018 7:44 am
Update: I graduated basic training. Now I'm going to AIT (Advanced Individual Training) to learn how to work on the Bradley fighting vehicle. I should have some phone privileges a little more so I can order parts. My budget has significantly gone up, I'm not too worried about price now, but still want to keep it reasonable.
To restate where I was in the build, I got the block bored .030 over and finished my intake manifold. Still need a head (plus the machine work and parts for it, pistons, connecting rods, and a cam.
Anyone have an 85 model head they would part with?
Users browsing this forum: old28racer, THE FRENCHTOWN FLYER and 64 guests
