2018 Contributors:
which manifold gaskets?
inline
Post #1 by inline » Wed Dec 06, 2017 12:18 pm
Sixers: What are your preferred manifold gaskets for the 300 with OFY 6019 and efi split exhaust? Make of gasket and year of truck please.
Thanks, JB
THE FRENCHTOWN FLYER
Re: which manifold gaskets?
Post #2 by THE FRENCHTOWN FLYER » Wed Dec 06, 2017 1:22 pm
Mr Gasket #260. Soak them in water before installation.
inline
Post #3 by inline » Wed Dec 06, 2017 1:48 pm
F. Flyer: Thanks. For how long do I soak them, and wil the bolts need to be retorqued as they dry out? Thanks, Inline.
Post #4 by THE FRENCHTOWN FLYER » Wed Dec 06, 2017 3:46 pm
They have a tendency to get brittle over time if left on a shelf. I hoard them so mine may be very old when I am ready to use one. Soak it for an hour or or wrap it in a wet towel.
Its always a good idea to recheck torques after running an engine for the first time.
old28racer
Post #5 by old28racer » Sun Dec 31, 2017 7:12 pm
TFTF ------ Is the Mr Gasket 260 still the best for my 300 street motor with Offy Dual Port Intake and Ford HD Exhaust manifold? Does Fel Pro make a good gasket for this combo?
Bad Day Racing Is Better Than A Day In The Stands :mrgreen:
Post #6 by THE FRENCHTOWN FLYER » Tue Jan 02, 2018 6:01 pm
I never ran a HD exhaust manifold so I can't answer that one intelligently.
wallen7
Post #7 by wallen7 » Tue Jan 02, 2018 6:15 pm
Fel Pro is a 2 piece gasket - it uses a factory style intake gasket over a exhaust manifold type gasket. Just take care when installing. I used some w/strip glue or dry tack glue in between the 2 gaskets to make sure they would not shift while installing. It seems to help. They are good gaskets.
wallen7
Post #8 by wallen7 » Tue Jan 02, 2018 6:17 pm
Another tip - do not tighten the 3 bolts that hold the 2 manifolds together until you tighten the manifolds to the head.
woodbutcher
Post #9 by woodbutcher » Thu Jan 04, 2018 9:00 pm
:hmmm: Hi wallen7.Hes using the EFI manifolds.He won`t have to worry about the three bolts.
Good luck.Have fun.Be safe.
Leo
Otto von Bismarck
wallen7
Post #10 by wallen7 » Fri Jan 05, 2018 2:14 pm
Thats not what he put in the post. He said " Is the Mr Gasket 260 still the best for my 300 street motor with Offy Dual Port Intake and Ford HD Exhaust manifold? Does Fel Pro make a good gasket for this combo? " That is the question I was answering.
wallen7
Post #11 by wallen7 » Fri Jan 05, 2018 2:15 pm
Old 28racer jumped in and asked that question.
woodbutcher
Post #12 by woodbutcher » Fri Jan 05, 2018 3:41 pm
inline wrote:Sixers: What are your preferred manifold gaskets for the 300 with OFY 6019 and efi split exhaust? Make of gasket and year of truck please.
Thanks, JB
:wink: Please note his first post.Thanks.
Good luck.have fun.Be safe.
Leo
Otto von Bismarck
Fordman75
Post #13 by Fordman75 » Sat Jan 06, 2018 3:06 am
My choice is the Remflex # 3005. It's a good gasket but it's not cheap.
http://catalog.remflex.com/FORD_Header_Exhaust_Manifold_Gasket_p/3005.htm
Ted
54 Ford F100/F150 4x4
Users browsing this forum: No registered users and 16 guests
