2018 Contributors:
Multiple carb Intake ?
1952ford
Post #1 by 1952ford » Mon Dec 18, 2017 7:22 pm
I have been thinking of Building my own intake. The options i have come up with are
3 holley 94s Old but rebuildable
3 Carter YF newer carbs and a factory option
and what about 3 weber 40s? 6 barrels? would look cool
or two autolite 2150s or 2100s
I like the idea of the 3 Webers for the looks but i would assume with 3 carbs the intake would need almost NO plenum
Any ideas
red1952
CNC-Dude
Re: Multiple carb Intake ?
Post #2 by CNC-Dude » Mon Dec 18, 2017 7:44 pm
Weber's are primarily an IR style carb and need no plenum. Many have used the newer 300 EFI lower intake runners and fabbed a top and plenum for multi-carbs. FTF has done it and a few others have also. Seems to have worked out well for them.
1952ford
Post #3 by 1952ford » Mon Dec 18, 2017 8:12 pm
CNC-Dude wrote:Weber's are primarily an IR style carb and need no plenum. Many have used the newer 300 EFI lower intake runners and fabbed a top and plenum for multi-carbs. FTF has done it and a few others have also. Seems to have worked out well for them.
I have entertained the EFI lower idea.....but now i see someone on Ebay is selling lazer cut flanges for the intake.
Do you think the webers would be best for a street engine in a light car?? or maybe the motorcraft 2100 ?
red1952
THE FRENCHTOWN FLYER
Post #4 by THE FRENCHTOWN FLYER » Mon Dec 18, 2017 8:14 pm
Re: 3 YF carbs
If you go to http://www.inliners.org and look on the Tech Tips page you will see a 3 x 1 intake made from three stock 1V intakes. Might be your cuppa tea.
1952ford
Post #5 by 1952ford » Mon Dec 18, 2017 8:45 pm
THE FRENCHTOWN FLYER wrote:Re: 3 YF carbs
Thank you
I seen that article. Do you think the 3 YF carbs can use a plenum?? or make a intake IR ?
red1952
Post #6 by THE FRENCHTOWN FLYER » Mon Dec 18, 2017 9:20 pm
I think you would have less problems with a common plenum, especially if you have progressive linkage.
jdn21758
Post #7 by jdn21758 » Thu Dec 21, 2017 12:44 pm
i used carter YF
jdn21758
Post #8 by jdn21758 » Thu Dec 21, 2017 12:46 pm
jdn21758
Post #9 by jdn21758 » Thu Dec 21, 2017 12:48 pm
jdn21758
Post #10 by jdn21758 » Thu Dec 21, 2017 12:54 pm
watch the link below for watching you tube
greeeetzzz JAN DOUWE NOORDENBOS (the Netherlands)
woodbutcher
Post #11 by woodbutcher » Thu Dec 21, 2017 3:45 pm
:D Hi JDN.Good to see you posting again.Merry Christmas and a Happy New Year to you and yours from me and mine.
Good luck.Have fun.Be safe.
Leo
Otto von Bismarck
Post #12 by THE FRENCHTOWN FLYER » Thu Dec 21, 2017 4:33 pm
That's a real nice Mustang. It would be right at home cruising Woodward Avenue.
Users browsing this forum: Angelking, Baidu [Spider], Google [Bot] and 22 guests
